Draughon
Daylon
Dallas
BMW 4-Series
I just made an $1800 mistake with my springs and need to fix it.
https://www.bronco6g.com/forum/threads/dobinson-heavy-duty-springs-dont-do-it.86856/
Do you happen to have the compression ratings (lbs/inch) for the springs and coilovers?
Hey all!
Eibach just released their Pro Lift Kit for the 2021+ Ford Bronco’s equipped with Bilstein PSD Shocks (Sasquatch Package)!​
These not only raise the truck 2.3" in the front and 1.6" in the rear, but also provides a balanced ride quality, control, and improved off-road capability.
By optimizing height and rate within the limit of each shock, you retain factory ride characteristics and a lift ready to tackle the toughest terrain, as well as more comfortably support a larger wheel and tire combo!
Manufactured using championship winning race spring technology
  • Finished in Heavy-duty corrosion resistant silver coating
  • Limited Lifetime Warranty
  • Made by Eibach in the USA
If you’re looking for more lift and suspension, check out Eibach’s Pro Truck Coilover’s for the Bronco’s as well!
These are fully-adjustable performance coil-overs that provide up to 4" of lift and the perfect balance of off-road performance and control.
We currently run these on our First Edition Sasquatch and couldn’t be happier with the ride!
  • Pre-assembled for direct bolt-on installation
  • Utilizes our ERO Championship proven Off-Road racing springs
  • Designed to work with factory control arms for an increase in height without accelerated wear to ball joints and bushings
  • Developed specifically to provide a balanced ride quality on and off-road
Of course, feel free to reach out to any of us here at Lethal Performance if you have any questions!
Aeromech2284
2013 F150 FX4
Anyone have a current promo code for the Eibach springs?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
bigblockfox545
jared
surrey bc
1991 FOX 2009 M3 2008 STI 2005 F350 2018 OB
Finally got around to installing the eibach springs and 37x12.5x17 bfg ko2's. Haven't had alot of seat time yet so will save my review for now. Also will test to see of i rub off road and report back. No rub of any kind so far. I would definitely recommend a adjustable trac bar. I went with the rough country in case I ever decide to lift it further one day.
Ford Bronco Eibach Pro Lift Kit for the 2021+ Ford Bronco (Sasquatch Package) 1000005730
Ford Bronco Eibach Pro Lift Kit for the 2021+ Ford Bronco (Sasquatch Package) 1000005731
Ford Bronco Eibach Pro Lift Kit for the 2021+ Ford Bronco (Sasquatch Package) 1000005729
Ford Bronco Eibach Pro Lift Kit for the 2021+ Ford Bronco (Sasquatch Package) 1000005728
nwGTS
Nate
Chicago, IL
Porsche 911 GTS, BMW M3, VW Golf
To confirm.
You installed just springs?
What was your lift amount on the new springs?
37s are a great look on the 4dr. So meaty.
bigblockfox545
jared
surrey bc
Yes eibach springs on a factory bilsteins, sasquatch black diamond. Also has bora 1/2 wheel spacers. Not sure on the exact amount of lift. With the tires I would say 3" in the front and 2" in the rear.
Perfect amount of lift I think. Can still fit on the upper deck of the local ferries. Don't have to deal with being over height.
paleh0rse
Bronco and others
Did Eibach ever release a different set of springs for 4dr vehicles with more/heavier gear ("overlanding springs")?
AZBronco73
AZ
2022 Badlands SAS, 2015 Dodge Durango
Unfortunately, they are working on them for their Coil-overs, but the are not ready yet. They have heavier duty Front springs in production run so probably a month or less til they are out. Rear springs are another story. They are still in prototype stage with the rears. I have been calling them monthly for almost a year waiting for them to finish them.
The part number for the front springs for their coil-overs will be 1600.3035.0500S and 1600.3035.0550S for 500lb and 550 lb rates. So when those hit their website, they are ready to ship. The are going to be different than their standard generic 16in springs (1600.300.0500S and 1600.300.0550S) that they currently sell, although I know several people that have used these for the front with after market bumper/winch extra weight up front (Panda sells them this way as an option for the fronts).
I need both front and rear heavy duty springs as I have the Rockhard 4x4 swing gate bumper/tire carrier with gas cans and a BAMF front bumper with winch, and Rockslide engineering steps, so my wife's Badlands SAS is a heavy girl. So I have to impatiently wait for the heavy spring. I went with Eibach's coilovers to basically get me back to stock height with all the weight (about 3/4 above stock from their 2.0 to 2.5 inch coil-overs), but I would love to get the heavy springs to be able to move to 37s.
