On the Bronco with the eLockers, what is actually happening mechanically when the rear and/or front diff is locked vs. something that has a limited slip diff with lockers?I'm going to push back a little here. It's true that the terminology has been diluted some, in general, the term "eLSD" typically refers to a limited slip design that is electronically adjustable. By that, I mean LSD hardware that responds to electronic controls. This is done a bunch of different ways, but there is a lot more to it than just the combination of an open diff and traction control.
More often than not, eLSDs have a clutch pack, and the load across the clutch is adjustable. In a few cases, the clutch pack was actually next the differential, but usually it is inside the diff (just like a conventional LSD). 15 years ago, Dana made a design that used a gerotor pump to create hydraulic pressure to compress its clutch. The electronic control was in the form of a bleed valve that allowed it to dump pressure.
Fast forward to now, the current Expedition uses an eLSD with a hydraulic pump mounted outside the axle carrier. The pump pressure is electronically governed, and works a piston on the end of the diff case. An apply plate pushes through the diff case to operate a clutch. I actually just ordered one of these this morning for benchmarking R&D work. There are also designs that use a magnetic coil to operate a ball cam, which operates the clutch. Others still use a motor and sector gear.
The bottom line here is that there are a lot of different versions out there that use actual adjustable hardware, which lets the computer change the locking effect / torque bias ratio of the differential, and do so on the fly, extremely quickly. Top model Corvettes and Camaros have used these to adjust their diff's performance and tweak it to each corner they apex on a track. OTOH, vehicles like Expedition use it to make it more stable in towing and to add to off-road capability while still maintaining good road manners.
With all of that said, Bronco does not use an eLSD in any of these forms (though it will have traction control). Basic axles have open differentials. Some packages/model include eLockers (not to be confused with eLSD), that allow the open to be locked on demand. But no eLSD.
On the Bronco if the with the diffs "locked" will both tires spin at the exact same rate regardless of traction? Or will the open side only get power if the other tire isn't getting traction?
