mpeugeot
It’s completely undetermined. I looked at the strategy codes of the ATCM which is the actual module that controls these modes and it would appear there are some differences between trims but not 100% confirmed still if that matters in the end. I believe the strategy codes would be tied to the factory installed hardware so that it wouldn’t try to enable something that didn’t exist say a sway bar or locker.
If you’re willing to try it out please let me know.
I believe that Pickens ran into this problem on their E5B Bronco and trying to enable Baja mode without the advanced 4x4 or rear locker (it was throwing codes according to them), likely because Baja mode wants to enable the rear locker or uses the advanced 4x4 transfer case for other trickery. Unsure why yet, that's just a hypothesis.
Mike1976
Fort Collins, CO
05 GX470
I should be picking up my Base Sasquatch by the end of the month in Colorado Springs. I have experience with Forscan from my F-250, so I should be able to try it out with some help. I am really interested in seeing if Rock Crawl works, as that is the only mode I am missing that I care about.
Mrpenn46
Nebraska
Badlands - Cactus Gray
That’s pretty lame that Sport is in the programming but disabled 🤬
It's not actually that surprising, why would they make a half a dozen different programs when they can make just one and just turn features on and off?
mpeugeot
Interesting yes very well could be. It’s unexplored by me and so far anyone else.
They do appear very fresh to ForScan and all the things they flashed were very very basic. The mention of Start/Stop and it throwing codes is unusual. I still haven’t had any issues with it on my end in regards to that. It throws a code initially but once cleared it has remained cleared.
Flashing G.O.A.T. Modes will absolutely put a bunch of codes and errors in the vehicle but once cleared they should stay cleared. Again however, all of this is unverified and I’ve only poked around in one trim level. I’d love to get access to a different trim or hope someone here will eventually try.
I should have my OBX soon... We shall soon know. I have an E5C advanced 4x4 with rear locker coming, so that may be an interesting comparison. If they would just get the train moving again. My Bronco is 252 miles away (311 miles with a detour through SATX) in Hearne, Texas!
EOSeabee
Patrick
Las Vegas
2022 Ford Bronco 4 Door Badlands
@D2dhanover figured out how to unlock GOAT modes with Forscan. I tried it tonight on my Badlands and instant sport mode. Took less than 5 minutes. Went on a test drive and everything seems to work exactly as intended. Activates 4A, has the full graphics package, different transmission tuning, different steering feedback, changed throttle response. To those who bought a wildtrak over a badlands to get sport mode you may have been shortsighted. Fortunately it’s not too late to change for a lot of you. Don’t pick your model based on GOAT modes. The true test will be for someone with a base to try. Or say someone with an OBX to try rock crawl.
Instructions:
Can you provide a link to ge the hardware?
webspoke
Stan
Pilot Point, TX
F450, GT350
Did my 60mi round trip commute to the office today with sport mode enabled on my 2.3 manual. This is they way it should come from the factory, crisp throttle response, feels easy to get into the torque band without a lot of throttle movement. I know it is just amplifying my inputs, not really changing the power output, but it just drives better.
The GOAT mode update threw a code on the ABS module, but it was able to clear it on the first try. I'd really like to get rid of eco mode, as I am not going to use it, and it would save a click of scrolling through it to get to Sport.
mpeugeot
Making the default mode sport would be a better option.
Mybbackpacker
Chad
Oklahoma
08 FJ cruiser (just sold), 18 F150 FX4
Some features of FORscan are free, but you can also get a 2 month extended license trial. I believe you will need the extended license for changing the ABS module.
MJJ
Sean
Iowa
JL Wrangler Rubicon, Jeep Wagoneer, Colorado ZR2
What happened to the “put the badlands in Baja and then adjust the dial to manually adjust to 2wheel drive” essentially giving it sport plus mode.
This was discussed over a year ago. Doesn’t require for scan. Videos exist showing how to do this on raptor trucks. Since I am still waiting for mine I can’t prove if this is real or not
AZ_Liberty
2007 Expedition
Is it maybe a weight thing? Ford not wanting to encourage people to tear down roads in a 5200 lb. vehicle?
Ford Expedition has Sport Mode as one of the standard driving modes. Expy is heavier than Bronco.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Earlier in this thread they established it still drives different than sport mode
Daktari
Oliver
from all I read here, not the same at all. Baja seems to keep it in much higher revs to speed over sand dunes, seems almost unpleasant on the road. I actually have not even tried it yet in my BL, normal is pretty peppy already, definitely for my around town driving and getting on freeways.
That being said, I'll still add sport via Forscan because I can and it should have been there to begin with. Might get to it this week, not sure yet.
Mybbackpacker
Chad
Oklahoma
I am looking into this but I will probably not find time to get to trying it until this weekend.
And yes I apologize for not clearly pointing it out. Once I finish some testing I will get with the OP so he can update this post or perhaps I'll make a new post and get it stickied. Writing to modules generally throws codes, sometimes silent sometimes with dash lights. Writing to the ABS module specifically can be terrifying for first timers because your dash will go crazy and you will hear sounds and chimes. But as you have said, and as should be definitely clarified, you need to clear codes after you write changes. It ensures you will have succeeded in making a modification. It's the final shakedown to make sure what you changed not only works but will continue to work and there is nothing wrong. Also sometimes other modules that you didn't make a change to will throw a code so while it's usually a false positive, clearing DTC's after writing a change will for sure rule out issues or inform you that what you changed could be correct it just requires a mutual change in a different module.
Example being with me trying to add Lane Centering. I am only finally able to get Stop & Go to work because three different modules needed exactly the right changes otherwise it would throw a DTC because it knew the configuration was incorrect. They basically check and verify each other to make sure what is being requested is correct and allowed. Not to say modifying these settings is exactly fool proof but these modern vehicles are very much aware of what they should or shouldn't be doing. A lot of the software features are very generalized to be a one size fits all across a fleet. Especially in next-gen systems like with Bronco.
Thanks for posting this info. I just drove mine and it does feel better in Sport. I really don’t get not including it.
