- First Name
- Brian
- Joined
- Sep 14, 2023
- Threads
- 15
- Messages
- 1,520
- Reaction score
- 2,240
- Location
- Central CA
- Vehicle(s)
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Your Bronco Model
- Big Bend
- Thread starter
- #1
tl;dr --
How the F*** do you get the new axle in the differential to lock in? Mine is about an inch away from fully seated, but I can't get it to back out or push in. It was very difficult to get out.
Long Story --
So, about a week after I replaced the shocks I took it out on a new trail. It ended up being a bit gnarly, but made it back ok.
About a week later - noticed I had a blown drivers side outboard CV boot. As soon as I noticed it was blown, I also noticed it would start to click at full steering while backing up. So I don't know if I dorked it up while doing the shocks, or if it was something on the trail, but it happened. So I'm gonna fix it.
Looking it up - it appeared just as well to replace the axle as to try to repair the boot, and since it was starting to click, I figured it was probably a bit more involved than just "new boot".
So, I ordered a new axle. Watched a couple of youtube videos. Searched around here and couldn't find much, other than a post by @Snacktime saying he did it plus the RC rack bushings in about an hour.
I think "Hey that's a good idea since I'm in there" so I order those too.
I figure - ok, I'm no mechanic, so longer than an hour, but it doesn't look too complicated so maybe an afternoon?
I started today around 1pm. First issue was I couldn't get the LCA off the knuckle; it wouldn't budge at all... so, I just took the back camber adjustment nuts and bolts off like I did for the shocks - that let me get half the axle out. The diff side would not budge. I had to pry and beat it about an inch and a half before it finally broke loose and pulled out. That took... 3 hours. (told you I was no mechanic)
Ok, so with the axle out, I cleaned up the mess from the blown boot, got the RC bushing in place (that wasn't terrible), and go to put the new axle back in.
Twist and push, twist and push, I finally get it to start to seat in the diff, it slid in about 1.5 inches from fully seated. But it's stuck, won't pull back out, won't push in any further. I tried beating on it semi-gently, but it has so much play that's hard to do to any effect. I got it in about another half inch, but I'm still an inch from being fully seated.
I kinda stopped here, after mangling the first few threads on the axle (did get that fixed) and getting just stuck without going and getting a bigger hammer. And the mosquitos were coming out in force. So figured I'd call out for some help.
Any advice?
Long Story --
Any advice?
