Has a V8 swap happened yet?
greenmachine343
md
bronco
  • Thread starter
  • Banned
  • #1
So the vehicle has been in people hands for quite some time now. Has anybody pulled off a v8 swap? Or is it impossible?
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Definitely possible from the physical side but integrating with all the electronics will be a task, though not impossible. I'm a little surprised an LS-swap hack job hasn't showed up by now.
adamruiz2001
SoCal
Ford SVT Lightning
Big Boss
Outer Heaven
Bronco Big Bend
I am the first to admit I am not the most mechanically inclined but I do know that modern engine swaps in modern cars are a royal pain in the ass. Getting everything to work the way it is supposed is a major hurdle
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
How about a Cyclone Swap? Is that feasible?
Theherofails
Thomas
Phoenix
I'm curious where they're gonna put it. Engine bay is already tight with the V6 option.
Murph914
Franklin, MA
2008 F-350 reg cab srw v10 manual
It’ll fit, but it would just be an engine and the body. Without the engine interfacing with the body nothing will work. No gauges no ignition no windows nothing. Several have discussed it, but all have said until Ford opens up the software its kind of a silly swap. Meanwhile there is the Bronco R for $250,000 off road only.
jasonf
jason
california
f150
ragingbullmarketing v8 was at sema
MNBigfoot
MN
It’ll fit, but it would just be an engine and the body. Without the engine interfacing with the body nothing will work. No gauges no ignition no windows nothing. .....
That sounds about perfect, except for the windows. Toss in a manual transfer case and a push button starter and call her good enough.
Last Ride Bronco
southern USA
Nissan pup
I wouldn’t be surprised if someone tries to convert a Bronco to full electric. They have kits right now to convert classics to ev.
Murph914
Franklin, MA
May as well get a gen1 at that point. It would be cooler. G6 only works if the tech works too
ctandc
VA
'22/23 Bronco, 96 EB Bronco
It's doable. I've seen and helped with modern V8s swapped into much smaller engine bays than the Bronco. Interfacing all the electronics is doable. Plenty of standalone aftermarket systems and programming options to keep most, if not all, electronic systems.
Hell, there's a bolt in kit now for a LSx swap into the FRS / BRZ platform and plenty of V8 Miata's running around.
Honestly, I'd say that the Bronco platform has an advantage from mixing /matching - most everything could be adapted from the existing F150 platform, especially from the electronics / computer side. I'd wager that a 3.5 EB would be the best option - even over the Coyote. The 10R60 would have to be beefed or likely swapped to the 10R80.
