flip
Phil
IN
www.ruxerparts.com
Fords
Catalogue shows it like this. Any of the items that have a shape is sold together but they can also be sold individually depending on what it is. In the inner kit, it's the green triangle pieces. Orange square is the outer tie rod, white square is a short rack, green pentagon is long rack and purple rhombus is just the boot and clamps.
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT 1686069386839
BAUS67
redneck
Central PA
A purple rhombus ?????????? I thought that was a purple diamond. :LOL: Oh well just like the "pound" sign (#) is now hashtag. :rolleyes: I can't keep up with this renaming stuff. 😁
Note to self: ..............No more diamonds they are called rhombus.
V1Rotate
Brevard, NC
2022 Wildtrak
If we’re getting technical with the renaming of stuff I believe diamond was the lazy re-brand of the original rhombus 😆
flip
Phil
IN
www.ruxerparts.com
Fords
Don't know the technical term Ford uses but figured rhombus was as close as I could get.
MUDLVR
Justin
Colorado Springs
2022 Badlands Sasquatch
Here's a list of short racks. The replacement suffix is next to the old number.
Long racks.
I just got the part number from the service tech: MB3Z*3504*AR
I see you have one listed there with a G at the end, but then handwritten is AR next to it. What is the difference?
And my service tech still doesn't know when I will get my new rack in from Ford.
I also, just talked to Tyler (Broncbuster) on the phone to see if he had any extras and he has a couple racks but they have different part numbers.
flip
Phil
IN
www.ruxerparts.com
Fords
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT 1686073158829
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
What did he say when you asked about doing a swap? Also I have one used
MUDLVR
Justin
Colorado Springs
Thank you! So if I'm reading this correctly, I won't see one until first week of July most likely. I might just get the HOSS 3.0 and have mpeugeot program it for me.
MUDLVR
Justin
Colorado Springs
Tyler said if he had the correct one for me, then he would send it to me, and then when I received mine from Ford to just send him that one.
What part number is yours? The one I need is MB3Z-3504-AR
Bmadda
Wisconsin USA
Here's the only #s I could read. AFAIK original unit 22 BL. worth $400 as a core, but perfectly good when removed
MUDLVR
Justin
Colorado Springs
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT 20230606_125628
Thanks for the pics. None of the numbers match up though with what is on @flip 's screen shots on page 90 though. I wonder if he has some insight.
Bmadda
Wisconsin USA
They wont add up cause they are engineering #s. Leme try running the vin on repair link
EDIT: after checking the one I have decodes to MB3Z-F or -C. -AR is w/Sasquatch...that one is non-sasquatch BL (so WTF is the difference there?)
flip
Phil
IN
www.ruxerparts.com
Fords
The build date range is 5/3/21-5/17/22. Only way to be sure is looking it up by the VIN. This is the LONG rack.
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT 1686076443571
Short rack is. Only difference is no outer tie rod ends.
Ford Bronco HOSS 3.0 severe duty STEERING RACK and TIE RODS ...Ford Performance M-3200-WT 1686076654919
Bmadda
Wisconsin USA
I did check Hoss 3.0 racks as well. Available in PDC (Memphis?). Not Chicago anyway...he said 2-3 days out, usually that means Memphis for us in the Great Lakes region. Chicago is overnight. Either way, can be had!
87-Z28
Andy
BMW
If the racks are physically the same dimensions, one has to wonder if the motor is any stronger or if the pulleys are different sizes to provide more torque.
very curious about this…
got me thinking about what the known differences are between the Ford racks. I think my head actually exploded. It would be great to have this data all summarized in one place.
it would be nice to start a new dedicated thread for this. We can keep updating as new knowledge is gained.
