How is your Rough Country tailgate reinforcement plate holding up?
Mpali
Illinois
2022 Wildtrak
For those that installed the rough country tailgate reinforcement plate. How is it holding up through the winter? Is the powder coating showing rust?
Lifeliberty
Moonbeam👀
Columbus, OH
powder coating is fine. Bolts are rusting
Grumpy
Who's
On a Lake
22 2dr
I've had mine since Aug 22, still looks new.
cgv
Apex, NC
Bronco Badsquatch, Explorer ST
Tried to install one, holes didn't line up and powder coat was missing from almost all of the holes. Bought hammer built and haven't looked back. I'd suggest steering away from RC.
Classic28
Brandon
Maryland
Nissan Titan
Powder coating is fine but I replaced the bolts because the originals were rusting. I also had to enlarge the holes where it bolts to the tailgate. It was pushing the tailgate towards the drivers side and the gaps weren’t correct.
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
I have had no problems with mine.
Mpali
Mpali
Illinois
2022 Wildtrak
I just installed my today. I am scared of aftermarket powder coated items. I have bad luck with them rusting eventually. I purchased the bolts and washers (black) to the carrier from a bolt company. Hex flanged bolts black like factory but longer 30mm.
Mpali
Mpali
Illinois
2022 Wildtrak
My gaps were a little off too at first. So I loosened up the 4 tailgate bracket bolts and shifted the plate so I can thread the carrier bolts by hand. Then tightened all carrier bolts then tailgate bracket bolts. Finally torqued to spec.
Mpali
Mpali
Illinois
2022 Wildtrak
What's the best touch up paint and color to use on that RC reinforcement bracket?
swaing
Gary
Belleville, Il
4dr Ford Bronco Wildtrak with Sasquatch package
Where do I find the factory torque specs for the rear door bolts?
Mpali
Mpali
Illinois
2022 Wildtrak
Someone on this board had this information to share
Ford Bronco How is your Rough Country tailgate reinforcement plate holding up? 1678020625380
HeliPilot
Kenny
CT
2022 2.7L SAS
Mines holding up fine
decummins
Daniel
New Hampshire
2022 Bronco Wildtrak
I had the same experience. Little tight.. but loosening the tailgate hinge bolts allowed me to put it all together just fine.
