IAG LED Dome Light Kit Aux wiring install
BRONBO
Alex
VA
Has anyone just flipped the harness and installed it using the connection up at the top of the windshield?
mmaturo
Celebration, FL
C8, R8s, Q7
That was my first thought also and what i may try to do so i don't run down the A pillar. With tomorrow being the super bowl it may be next weekend before i get to this.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
On a manual Bronco that grommet spot is used for the clutch master cylinder line.
Assuming there’s still some room to pop a hole for an 18g wire? I also plan on sending the power adapter wire for the Kicker Key…
Ducati1098
2022 Bronco Wildtrak, 2012 Ford Fusion
I’d assume so. But I have an auto, so I can’t confirm.
BRONBO
Alex
VA
I just got done installing it and ended up flipping it. have a lot of excess wire up above the visor. Was thinking of cutting it down but didn’t want to mess with that at this time.
Only issue I had was getting the ground to work properly. Saw someone had the same issue where the lights were about 5%. Tried adding a washer but didn’t work for me. Ended up putting the ground between the chassis and bracket And it worked.
mmaturo
Celebration, FL
C8, R8s, Q7
Great. Good to know and I assume besides the ground easier. I am after just using the switch so will do the same.
coreymd
Corey
DFW, TX
'22 Bronco, '20 HAH
Connected mine to AUX4 without connecting into the door wire. Although I ran the harness to that location in case I change my mind.
I went the slightly harder route and ran a 16 awg wire up the driver's A pillar, through the overhead trim, down the passenger's A pillar and into to the glove box area. Wired into the factory white wire there (B2).
That was a ton of work, but I was set on removing most of that trim anyway to re-run the power cable to my dash cam, since my first attempt was pretty janky. Also, I have a manual, so I elected not to find my own route through the firewall.
Anyway, works great after all that and mercifully, it lit up on the first test.
