I'm an Idiot or Going Insane [Updated With Final Location of Key Fob 🙀]
Status
Not open for further replies.
MNBigfoot
MN
My wife had a similar situation w/ her Terrain and tried the same with a much different result...the truck fired right up so she figured the FOB was somewhere in the truck and off she went to the gas station. Turns out the FOB (and house key) was actually 8' feet away on a shelf in the garage. When she finished fueling up the FOB was now 2-3 n miles away in a locked house...there she was stranded at the pump. She was not happy...even less happy when she got home to retrieve the FOB only to realize she was locked-out.
If you made it to your destination and you were able to re-fire the FOB has to be in there somewhere!
If I would attempt that is my wife's Toyota's, you get both an audio and dash message telling you your key fob is no longer detected.
Moyer22
2012 Wrangler
I need to know the ending to this lol. I don't think it's been said yet but maybe underneath the vehicle or in the yard? Like if you had it on your lap when you got out and it fell without you realizing. I'm new to the whole key fob deal so I'm super paranoid about it. Good luck.
Alexis England
Alexis
Northern CA
2000 Ford F350 dually 4WD
I had this happen the other day with the same kinds of feelings. Mine wound up being under my dog that was sleeping in the passenger seat. incidentally, the last place I looked. Good Luck!
Beachin 74
Delaware
It happened to me. Ended up underneath a water bottle in the cup holder.😳
BottleShark
TJ
East Texas
Nautilus, Samurai, 12v Dodge, Fiero, Karma Ghia
It’s always in the last place you look. Because if you found it and kept looking, that would definitely be on the insane side….
pimpjuice
ocala, fl
bronco
$10 says that thing is in between the bottom and back of the driver seat. Just recline your seat back and you will find it there.
Garbone
Gary
FL
1962 C10, 21 Mustang, 12 Explorer
Went to a theme park yesterday and locked my fob in the Roomba. Came back to the car 4 hours later and used the code to unlock the door. Roomba stated "no key detected" even though I had the fob in my hand. Had to start the car with the passcode on the touchscreen. Worked fine going forward.
Strange behaviours.
🤔. Maybe you could always start the Bronco without the fob and just never tried it. It could still be in the house behind the bench.
Julz670
Julian
Minnesota
www.youtube.com
Previously: '83 and '95 Bronco XLTs. RIP.
If OP still looking for that key 6 hours later, its not getting found... but im committed now! Watching
69 Mach I
Sean
'15 F-150, '87 Mustang
It has a small range from the ignition. Probably between the seat rail and the center console
This happened to me, except in the attempt to retrieve it I somehow hit the panic button. It was quite the scene in the Food Lion parking lot! :ROFLMAO:
Status
