- Thread starter
- #1
Crutchfield configurator says no-go, but I’ve seen posts from users installing these. Will they work in both dash and rollbar locations (non-B&O), and if so, do they require any modification?
Wondering if you ended up with the c2‘s and if they worked out, trying to decide between the c1 and c2 4” For the dash and pods in my raptorCrutchfield configurator says no-go, but I’ve seen posts from users installing these. Will they work in both dash and rollbar locations (non-B&O), and if so, do they require any modification?
I ended up using Polks.Wondering if you ended up with the c2‘s and if they worked out, trying to decide between the c1 and c2 4” For the dash and pods in my raptor
How is the sound for you after the change, did you just swap out speakers or did you add anything else, dsp, amp , etc?I run 4in JL C2's in my dash and rear pod and a 6.5in in the kick panel. They fit fine.
Did the kick panel fit without any mods? I was told that they'd need an additional 1/3" clearance by CrutchfieldI run 4in JL C2's in my dash and rear pod and a 6.5in in the kick panel. They fit fine.
Which exact models did you go with ? Im thinking of doing the sameI run 4in JL C2's in my dash and rear pod and a 6.5in in the kick panel. They fit fine.
