I thought you were suggesting that no wireless charging pad would charge while using CP/AA, excusing Ford's cheapo pad, because charging while using apps is an unreasonable expectation. I see now you're just pointing out that it's an unreasonable expectation for the Bronco charging pad.Where was I making excuses for Ford? I just said the wireless charging pad they used is weak and won't charge your phone when connected to AA/CP. That's not an excuse for Ford, just stating a fact so OP doesn't assume that pad is going to charge anything when connected. Also, you can disable the auto connect to AA/CP if you want, and set it to manual connection.
