Manual Sway bar disconnects
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Mine are the black ones. Neighbor’s are the silver ones. Both from AC Fab. Notice the difference on how the top connects to the swaybar.
Ah. Yeah. Mine are like yours. The black ones. I’d be curious to pick his brain on the differences. If one is better than the other or just parts available. I shot Oscar a message. I’ll report back.
CrystalRedTintCoat
BertJ
Bay Area
‘22 Bronco Wildtrak; ‘13 Camaro 1LE
Well, mine (ours) have to be adjusted. If you over tightened the top 3/4” bolts, the disconnect bar won’t move freely. His seems to be self-adjusted all the time.
Anyway, I don’t know which version is newer or better either. If you’re able to pick his brain, please post! :)
redone17
Cold Spring, NY
From Oscar: The studded heim just has a bit more articulation and also less parts that can go bad. Replacement set is $45.
CrystalRedTintCoat
BertJ
Bay Area
Thank you! So the one we don’t have is the studded heim? If you’re an existing customer for $45 he’ll make these available? Mine make an S-ton of noise. Even with grease every week.
redone17
Cold Spring, NY
Yeah, I just ordered a set. I’ll report back.
CrystalRedTintCoat
BertJ
Bay Area
I just left Oscar a message too. This clanking is killing me. When I disconnect the links to the sound goes away.
Hashlak
UAE
Bronco Sasquatch, Porsche GT3RS, Honda CBR1000RR
Any recommendations where I can get a standard adjustable (non disconnect) sway bar link?
Seems that bajakits is the only one brand offering this.. Any ideas? My stock sasquatch one has a torn boot and making noises, car is lifted about 3inches so I figured that its better going with an adjustable one to match the ride height.
CrystalRedTintCoat
BertJ
Bay Area
I just fully removed and reinstalled mine. I noticed each link has L etched into one of the ends. I assume this means Lower end ??? I also noticed that the lower end himes move freely, even with just your fingers. But the other end, on both units, does not move freely and a jimmy or screw driver shaft allows you to move the non L end himes. Going on a test drive now hoping the clanking has abated.
Fordified1
Bob
Mid South Texas
Is it even necessary to disconnect both ends of the sway bars? I simply disconnect one side on my Jeep, Excursion, and RZR. Works fine. Maybe the end of the sway bar will hit the control arm at full articulation?
jayhawkerr
Jay
Centennial, CO
'18 XC90; '14 Tundra; '71 Chevelle; '37 Tudor
The connected side will have the same limited travel that it had with both sides connected. It basically acts like a single limiting strap connected to the an arm if you disconnect only one side on the connected side.
Fordified1
Bob
Mid South Texas
Thats not how a sway bar works. It connects the right side to the left making resistance from articulation in opposite directions. The sway bar acts like a torsion bar from aide to side. Unless the Bronco is different somehow.
CrystalRedTintCoat
BertJ
Bay Area
No. The lower part has a lynch pin. Pull that and link comes free from the bottom and remains bolted to swaybar.
redone17
Cold Spring, NY
The upgraded heim joints look NICE. Sucks to have spent another $50 - but, looks to be a significant improvement. I probably won't get a chance to install until after winter - considering I just coated my undercarriage with Fluid Film - they should stay nice and lubed for a few months.
CrystalRedTintCoat
BertJ
Bay Area
I cannot seem to order these. Would love help. ;-)
CrystalRedTintCoat
BertJ
Bay Area
Oh, I bought the fluid film per your recommendation . Took off my links and fully lubricated all four himes. I noticed one end of both links was tighter and the other end was looser. In the tighter end is the letter L etched into the link-end metal.
