Mishimoto's Bronco 2.7 Aluminum Expansion Tank Poll
What color option do you prefer?
  • Polished
  • Wrinkle Black
  • If only offered in wrinkle black, I would buy and refinish
  • If only offered in wrinkle black, I would not buy
Results are only viewable after voting.
Mishimoto
New Castle, Delaware
F-250
Hey Bronco Team,
We are working on an aluminum coolant expansion tank and would like your feedback regarding color options. The stock tank is on the passenger side of the engine bay in front of the firewall. You cannot miss the semi-opaque tank with yellow-ish liquid in it! Luckily, we have an option for you in the works for people who don't like the way the stock one looks (or who are looking for increased coolant capacity). Even if you aren't concerned about the color of the tank, an aluminum tank will be more reliable than the stock plastic tank, keeping you on the trail and not pulled over with a puddle of coolant under your Bronco. Scope the renderings below for two color options.
Ford Bronco Mishimoto's Bronco 2.7 Aluminum Expansion Tank Poll Bronco OEM Tank
Ford Bronco Mishimoto's Bronco 2.7 Aluminum Expansion Tank Poll MM Bronco Tank Black Render.JPG
Ford Bronco Mishimoto's Bronco 2.7 Aluminum Expansion Tank Poll MM Bronco Tank Polished Render.JPG
Looking forward to your feedback!
- John P
Mishimoto
Mishimoto
F-250
Thanks, everyone, for the feedback on the poll!
DoYouBronco
Lux Sponsor (Level 2)
Tyson
El Paso
hpbuilt.shop
Gen2 Raptor Midtravel / TowRunner F250
crazy idea...
what about relocating the bottle elsewhere, and mounting the battery in that tank location so we can run a true dual cone intake system with the driver filter in the place of the oem battery.....
yippeekiyay
Bend, Oregon
2021 2-dr Badsquatch, 1998 Land Cruiser
Will there be a sight glass to check level? Not loving the idea of having to get a flashlight to then unscrew and check level...
MrGreen55
Kyle
Oregon
toyota scion xb
We will have a clear (with a sight backer) window on the side of the tank so you can check the coolant level. The "COLD" line on the side will help you make sure your coolant level (when cold) is in the ideal spot.
They said this in the 2.3 post https://www.bronco6g.com/forum/thre...minum-expansion-tank-poll.43610/#post-1396854
Mishimoto
Mishimoto
F-250
crazy idea...
Hey @DoYouBronco - Interesting idea. I'll run this by the Engineering Team.
Hi @yippeekiyay - Yes, thanks @MrGreen55 for the link to the other thread. We will have a clear (with a sight backer) window on the side of the tank so you can check the coolant level. The "COLD" line on the side will help you make sure your coolant level (when cold) is in the ideal spot.
Would love a sight glass like this rather than the bullseye.
Hi @mikec426 - Another interesting idea. I'll share this with Engineering.
- John P
Razorback
Bill
Dallas
Lincoln MKX
crazy idea...
I was kind of looking at that the other day. Seems where intake is located and how air is routed to it, doesn't seem very efficient. Sorry to side track the thread...
DoYouBronco
Tyson
El Paso
hpbuilt.shop
is there a tread about their bronco intake? if so , see ya there!
