I guess you want your Bronco to cost $100K+ for a base. There is an expense to redundancy like you talk about.In the Army we had to make what we called "contingency plans". If plan A doesn't work, go to plan B, then C and so forth. Ford clearly failed to have contingency plans, which should have been obvious to them that they needed to do so with the pandemic and all. They should have had multiple MIC top makers lined up should the first not be able to meet demand, multiple microchip manufacturers lined up and so forth. You get what I'm saying. When you tell a supplier that they will meet demand or they will be replaced with someone who can, companies tend to pull out the stops to make things work.
With that being said, I hope and pray your dealer is wrong or perhaps misunderstood what was told to them. If it is true, we shouldn't be surprised as this has been the "New Normal" lol with this launch.
Also, changing suppliers are easier said than done. First, there aren't many and their equipment isn't idle. Development lead time is years, not months. Worked for a supplier and GM tried doing what you're talking about. They brought in all our competitors, we refused to let them in our building and put anything owned by GM out front in the parking lot and said take it if someone else can make it. We didn't loose a single part that day.
