OEM LED taillights - where to buy besides dealers?
GusVG
Gus
2023 Bronco
Hey everyone,
I’m looking at swapping my standard taillights to OEM LED
besides the dealer, any recommendations on where I can get an inexpensive set?
Alfa
Diego
Austin, TX
Bronco Wildtrak
People sell them here occasionally. I broken the outside shell of my passenger side light and had to buy the entire unit since it is all fused together.
I found a ford unit on eBay, but eBay was full of aftermarket version that were MUCH less expensive.
RagnarKon
Ford Bronco, Escape, Focus
You can find them here on the Bronco6G marketplace or the Bronco Nation marketplace. Also all the usual spots... eBay, Facebook, etc. Sometimes people will swap out their factory tail lamps for different designs and sell their old ones here.
I will warn you that it's not a clean plug-n-play swap. The LED tail lamps have a different wiring harness than the halogen tail lamps. So it may be better to find aftermarket tail lamps that are compatible with your factory wiring.
GusVG
Gus
2023 Bronco
Thank you, I did see the aftermarket ones but i
thank you for that info, I’ve seen the difference in wiring
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Make sure to check out the ORACLE Lighting Flush Mount Tail Lights. These are an upgrade to the factory with a tight finish! Protruding out significantly less than the factory tail lights, this low-profile design helps avoid potential damage while trail riding. LED reverse lights will provide 1,400 Lm of high-output rear-facing illumination.
Ford Bronco OEM LED taillights - where to buy besides dealers? ORACLE_Lights_Bronco_LED_FLush_Taillights
https://www.oraclelights.com/collec...tail-lights/products/bronco-flush-tail-lights
GusVG
Gus
2023 Bronco
I do like them a lot, but way too expensive for me
GusVG
Gus
2023 Bronco
if you can provide a discount code, I'd be happy to purchase them
Alfa
Diego
Austin, TX
Bronco Wildtrak
I considered the Oracle tail lights because it was cheaper than buying 1 tail light from Ford. Ford price is $1000+ for 1 light. Ruxer discount still costs $650ish, again, just for 1. I was happy to find a gently used Ford one on eBay for $300. These things are expensive.
ORACLE Terry
Terry
New Orleans, LA
You got it!! My signature has the discount code for members of the forum. BRONCO10
GusVG
Gus
2023 Bronco
Yes, they are. I’m hopping to find some take offs at a good price, otherwise I may just go aftermarket
Oracles are cool, but I like the OEM stile even if they stick out
Thank you!
CUPRA
'21 Bronco OBXSAS/'23 Camaro SS Convertible
GusVG
Gus
2023 Bronco
2022obxblack
Jason
Raleigh NC
2022 Bronco OBX
So, new here as well. I bought a slightly used 2022 outer banks. Noticed there was a small crack in the right rear tail light. 3 weeks in the rear lights stop working all together and the dealership shows me a pic of the tailight inside the frame and it has a rather large crack in it. They think moisture/rain got in over time and caused a short. They replaced the bcm under warranty but wanted a $1000 to replace the one tail light. Been trying to find any info online for aftermarket replacements but seem more involved than a plug/play style light. Like the oracle but seems dumb to have to buy a forscan to be able to replace a led tail light with another led tail light. Like the smoked tail light look but not sure if something like that is available.
Modding my 6.7 F250 seems to be way less complicated than this new "work" toy 😂
CUPRA
Two posts up I posted a video of OEM style tail lights. There’s a smoked version and a red version and also the Raptor style tail lights. They are all around $300 for the pair and plug and play.
Links to them in the video description.
