Parking garage clearance issues
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
I recently moved back to LA and am having issues with parking garages with my sas 2DR. Visited a friend the other day that had clearance of 6’ 5” and it was so sketch but I made it.(antenna was hitting every pipe)
The garage for our new office is 6’ 4”… I’m at 6’ 3”. Should I give it a shot?
OtisFE
Otis
Alexandria, VA
2022 Bronco OBX
An inch is as good as a foot…
@BadBlueBronco
@BadBlueBronco
Kc
Los angeles
wetdog
Bruno
pacific coast
2019 jl
An inch is cutting it close low on gas ,heavy on air pressure,inaccurate height measurements could all conspire to ruin your day.
I would go into garage with a friend on the weekend when its quiet and have them spot for you as you drive slow .
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
One to two inches clear is cutting it close. You're relying on someone else to accurately measure every single spot. I've dealt with this for years, and I usually look for 3-4" clear (minimum) or I park somewhere else. Yes that sucks when you're in an urban environment...welcome to driving a taller vehicle.
bodean
Shawn
Alberta, Canada
76 Mini, 99 4Runner, 07 FJ Cruiser, 16 Tacoma
Ran into this the other day, truck fit in with about an inch to clear. The slight dip in the road on the way out and it just kissed the bar.
A little WD-40 and magic eraser and it was like it never happened.
Have since dropped the tire pressure to 30psi and make sure to keep the gas tank near full.
Ford Bronco Parking garage clearance issues C1E04C61-6628-4DAC-9731-81899FF6819F
Northridge4x4
Silverdale, WA
Lots of Jeeps and one lone Bronco (so far)
@BadBlueBronco
@BadBlueBronco
Kc
Los angeles
Update: it was very sketch but I made it. I don’t know if I will go below the first floor.
Gtrekker
Gary
My garage clearance 1.5". Strongly recommend a stubby antenna. The slapping is very annoying!!!
brentutk
Brent
Nashville, TN
Eruption Green Wildtrak
I work in very modern, brand new, impeccably designed office building in downtown Nashville. I can't enter it with my soft top folded back into the first position (but otherwise fits). I have to constantly remember that.
@BadBlueBronco
@BadBlueBronco
Kc
Los angeles
Lol I have a pretty funny video of me going 1/2 mph and the antenna hitting all the pipes lol
805Bronco
Camarillo, CA
1992 EB FSB Bronco; 2021 Outer Banks 2-Door
I had an issue with my '92 FSB several months ago at a LAX parking garage. It sits a bit over 6 ft at the cab. The starter died, and no matter how much I beat on it after a 10 day trip to MT, I couldn't get it to turn over. I was ready to uber 63 miles home and have it towed out of the parking structure when I found no tow rigs would touch the job given the 7 ft beam clearance. Thankfully, in frustration, the last whack I made against the stater loosened up those mags, and it turned over. From now on, we take the wife's Mazda 3 to LAX, lol...
Rick Astley
Up Doug's ass
d
Depends, are you a shower or a grower?
1" is not a lot of room for growth, but at worst you could skip leg day and air down the tires 10psi. I mean, it's LA, how hot could it get where you would need adequate on-road PSI?
Rick Astley
Up Doug's ass
d
Or just swap starters there in the garage.
