Jwall
Jason
Wentzville
Jeep JK
I know there is some controversy about how much payload some of these Broncos have…or don’t have.
4 door, base, Sasquatch, soft top, 2.7. It had just under a full tank, WITHOUT me in it.
Steer axle weight: 2,720
Drive axle weight: 2,120
Gross: 4,840
GVWR: 6,100lbs
Actual payload: 1,260lbs
72BroncoSand
PNW
72 Bronco, 77 f-150, Jetta Tdi, 1ton
Thank you for sharing! Useful info.
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
I've got the same truck, except for the top.
Knownman
Santa Clarita California
2021 Bronco Badlands Sasquatch.
Gross: 4,840
GVWR: 6,100lbs
Ford Bronco Payload and actual real world weight (scale weighed) of Bronco Base, 4 door, Sasquatch, 2.7 23687893-D763-4BB9-A88B-247BF5D87612
Nice post. Thanks for that
MDbeachguy
md
>actual payload
does this mean max weight you can add to the car???
what about 2 door?
bytheway
Brice
Louisville, KY
What's your payload sticker say?
jaruss01
Thanks. But am I missing an image? What's the number from the factory we should be comparing it to? Did you gain more payload? Not sure if Ford understated or overstated the gross weight.
Jwall
Jwall
Jason
Wentzville
Jeep JK
Jwall
Jwall
Jason
Wentzville
Jeep JK
For what it’s worth, my 2 door jeep on 37’s was only 100lbs less. It only had a 5,000lb GVWR.
It did have a 3/16” steel rear bumper, 3/16” steel skid plates, heavy wheels and suspension components.
2Jeeps&PatriotX1
Denver, CO
I was planning on weighing my 4dr BL non-squatch, lux, tow w/ soft top on Monday. But maybe I should actually do it prior to swapping out the oem top for the best top trektop this weekend to see what the weight difference is.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
That's not too bad.
I think part of the confusion is the offhand expression that small cars weigh one ton and huge cars weigh two tons. Cars have not been that light for decades. Sub-compacts that would have weighed 12-1600 lbs in the '70's are now over 3000 lbs but since they look small, most people assume that they are still light.
69351windsor
JW
69 Merc, Ranger, HD
Dave-O
College Station, Tx
F-150/Mach-E
4800lbs ain’t all that bad. My 2018 4Runner was about the same and our F-150 is closer to 4700 but that’s 2wd and all aluminum bodied. This helps make my decision for a base Squatch. How do you like it?
