Photos: RPG perch collar installed (on stock tires)
dumpsterfire22
Ryan
2015 F150 Platinum SuperCrew
I know when I was trying to find pictures of perch collar lifts, everyone had 37s. I just wanted to see how it would look with 35s because I wasn’t ready to take the $$$ hit right away and wasn’t looking to lose mpg. So for anyone curious, I have the RPG perch collars front/back with the stock tires and love the way it looks. Don’t think I will ever go 37s. Probably wear the stock tires down and go to a true 35.
Ford Bronco Photos: RPG perch collar installed (on stock tires) IMG_0469
Ford Bronco Photos: RPG perch collar installed (on stock tires) IMG_0471
Strykerwsu
Wichita
Holden Commodores
HOSS 3.0? Any real difference in ride?
Rumbloki
Alton
ATX
ZR2, 1973 Mach 1
Looks awesome! That is the stance I'm after, but going 35x11.5x17 on Badlands wheels.
dumpsterfire22
dumpsterfire22
Ryan
Thanks. The fifteen52 wheels I have are a 0 offset so they give a little wider stance. You might need spacers if your leaving the stock wheels on and are looking for the same poke.
3People1Body
Christopher
West Virginia
Wildtrak, F150 and Taurus.
Yes, there is a big difference (to me). The stock HOSS 3 floats over bumps like a tuned suspension... after the 2.25 RPG perch collars, I could feel the rear shocks kicking a bit. You don't glide over bumps, you now feel the front and rear independently, at least I do.
Strykerwsu
Wichita
Holden Commodores
Appreciate the feedback. I’m about to install on my sas obx. I have a front winch which didn’t cause sag on bilsteins but assume might on the 3.0s. We will see. 35’s are big enough for what we do.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Can we get a side profile shot? I was worried about similar as I am about to add SVC collars on non-sasquatch bilsteins after running sasquatch take-offs for 2 years. I want a stiffer ride, but likely won’t upgrade entire suspension to until it’s time for new tires.
I’m running 285/75 and was concerned it would make the tires look puny. I’m glad I might have nothing to worry about.
