- Brian
- Sep 14, 2023
- 13
- 1,249
- 1,812
- Central CA
- '23 BB 4dr 7MT, '22 BSport OBX, '87 B-II XL
- Big Bend
Been looking into this as I think I toasted my locker solenoid. Will drain and dig into it later this week - but just to post here so it's all in the same thread for other folks / posterity - and for other folks to look at in case I got something wrong here, as I'm still digging into this project and haven't finished it all up yet to confirm it's all correct:I accidentally cracked the plastic part of the locker actuator while doing my gear swap. Ford could not find a listing of only the actuator without the actual locker. But spicer sells it . Just an FYI. It was less than $80.
Took 3 or 4 days to get.
Ford doesn't sell just the solenoid, they will sell the entire carrier assembly (about $700+):
P/N: MB3Z-4200-B
But you can get the solenoid direct through Spicer (about $80):
P/N: 10102021
After unbolting the carrier out of the rear end, you just have to remove the
Ford P/Ns (requires both parts):
KB3Z-4221-B (bearing only)
NB3Z-4616-A (race only)
Spicer P/N
10275976 (bearing + race set)
This is the Ford parts diagram - note it does not show the coil as a seperate part, based on the linked post above it would be on the left side of the carrier assembly, on top of the ring gear (between Part #2 and Part #4 on the left side)
