Removed factory Bronco Sasquatch wheels and tires
MnLakeBum
MN and FL
‘18 Range Rover Diesel
whats a woman?
I've heard that the correct term that some would like to impose on all of us in the USA is: "birthing people" ;)
hdmontecarlo
Victor
TX
15 F250
What’s holding the spare on? Magic lol I can’t see any lugs. I thought I wanted sas wheels until 96% of broncos I see have them. Different is good make that ride to your liking!
3 lugs, I bought another center cap so can cut the center out for the rear camera. I still have to put my Rough Country reinforcement and relocation bracket and my XGlow 5th brake light on.
Jawbox
Greg
Crookston, MN
Bronco 4 Door
Gearing? That would be my guess.
Also, locking Front and rear diffs. Depending on the package, you need to go SAS to get Advanced 4WD as well.
Also, the SAS takeoffs probably pretty much covered the change, it's a win win. Someone that loves them gets a near new set of 35's and you get yours.
idobleedblue
4-door Badlands Sasquatch Bronco
I like them a lot. The only change I made was to paint the silver beauty rings black.
I'm thinking about painting mine (instead of powder-coating) so touchups after inevitable boulder-rash won't be as costly. How did you go about painting yours? I'm thinking scotch-brite pads to scuff up... primer... paint... clear coat? Did you do it yourself or have someone else do them for you? What was the process (if you did it yourself) if you don't mind me asking?
wedemmoez
Moez
Dallas
2021 Bronco Badlands, 2007 Porsche Cayman S
Super easy, there's a thread on the forums that has a how to.
the basic steps are
Use a TP40 bit to remove the beauty rings, wash them thoroughly, scuff up with scotchbrite or sandpaper, spray paint, let them dry, reinstall.
idobleedblue
the basic steps are
Thanks... I'll see if I can find that thread and read through it. Thinking about doing a body color-match for the rings. Not quite sure how it will look yet. Got a can of fighter-jet gray to try it out. If all else fails I also like the look of the black on black rings so that will be my fall-back.
Haystack
Earth
Yes
So much hate for someone that chose to be different than 99% of the Broncos. Not your cup of tea, move on to the next build thread that looks just like yours!
