Bigger tires on same factory wheels (Outer Banks non Sasquatch)?
ssil
NJ
I have a 4-door outer banks non sasquatch. My rims are 18” and my tires 32”. I love the look of the bigger tires but also love the rims my bronco came with. Does anyone know if I’d be able to keep the rims and go to 35” tires? Thank you!!
5GENIDN
Joe
Idaho
I think you may have a challenge with both the width and the diameter.....
First) I do not believe there are a lot of 35 inch tires made to fit an 18 inch diameter... I think there are a couple but not many... most everything seems to favor either a 17 inch or 20 inch.
Second) is your width. I am guessing it is an 8 inch width. If you are looking at a 12.5 width tire I believe the minimum recommendation is a 8.5 inch wheel. You might find an 11.5 width tire in a 35 but to find that and fit an 18 inch rim.... Good luck.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I think there are some companies that will widen the rims for you, if that becomes the limiting factor
GI_Jo_Nathan
Jonathan
You can also do 1.25" bolt on spacers. That will make a world of difference with the look of the stock wheels.
Stick with a name brand like BORA Garageline or Titan.
Brad
Strongsville, OH
‘22 2.3L Non-Sasquatch Black Diamond
I think you are correct on the diameter, but nearly every 35x12.5R17 out there is listed on Discount Tire’s website as accepting down to a 7.5” wheel.
I’ve been compiling a list of both 35” and 37” tires in preparation for upgrading my Black Diamond once I get my Sasquatch takeoffs and steering bushing installed. See the photo of my spreadsheet below. Ignore the total lift column, as that’s specific to the Sasquatch shocks and spacer lift I’m installing.
mrjking2000
Justin
Loveland, CO
2022 Bronco BadSasquatch, 2019 F-250 PowerStroker
you are looking for a "pizza cutter" tire. for example, my F250 has a 285 75 R18 on it which equates out to basically 35x11 and honestly it handles well and looks good. skinny tires have advantages, and wide tires have advantages.
i'm seriously looking at a 37 x 11.50 for my bronco, 1 it's lighter than its 12.5 counterpart, 2 it should fit better lock to lock on steering especially while flexed.
Derbystud
2011 F250 6.7
I know your wanting to stick with the stock OBX wheels. But here is my regular OBX with sasquatch take offs with no lift. I think it looks so much better with the bigger tires.
Hawkstone
MB, Audi and Ford
Ford Bronco Bigger tires on same factory wheels (Outer Banks non Sasquatch)? 20231128_131010
Check out Tire Rack. You can plug in rim size, etc., to your search. Good luck!
NVCowboy
William
Henderson, NV
2002 F350. 2022 Big Bend (Sasquatch)
Northwest Bronco on YouTube is running Black Diamond Steelies and Sasquatch sized tires with no ill effects, but his Bronco is a Sasquatch. Tires shouldn't be an issue, especially given the above posts. I'd recommend finding some Sasquatch take off springs and shocks for the lift to go along with the tires.
prospectfour
Pete
NJ
'22 Bronco, '18 Tiguan
Dang! 285’s are pizza cutters now?
I always thought it was those super tall 255/85’s I’ve seen here from time to time.
If OP is dead set on keeping the wheels he can do 295/70 which looks pretty damn good. If guys are throwing those on their super duties it will not look undersized on your outer banks.
Black_Stallion13
Cincinnati
Tacoma
I don’t think I’d try going over 33” tires with those wheels. Even the standard badlands with 33” tires has wider rims. If you want 35s easiest thing to do would be to buy sas takeoffs. I would also do it the right way and add Badlands suspension takeoffs to raise it up and inch or two. Doesn’t look right with stock suspension and 35s. Then of course you need to tune the ECU. Not cheap to do it the right way. Even then you will be worsening the awesome ride quality of the OBX.
mrjking2000
Justin
Loveland, CO
yeah those are not as common anymore, i guess anything narrower than a 12.50 on a 35 and up is "skinny" lol!
