Removing sound headliner if I don’t like it?
MacHudson
Northern New Jersey
2012 Edge
Badlands MGV person here. MIC top only. Lux too, so I do have extra sound deadening in my package. My order is in. I’m in this for real.
The free headliner sounds nice. The price is great. But what if I don’t like it? Too hot/cold, doesn’t do much for the sound, don’t like the look, patches won’t stick to it, etc.?
How would I change it out for the Hot Heads product without F’n up the look of the MIC top? Anybody been down this road with a Jeep?
Used2jeep
Massachuvian
2007 Crown Vic P71
The Hotheads are installed with double sided tape if I recall the video correctly. Shouldn't be too horrible. Be slow and careful and it should be fine. Besides, if it is on there when you get it, and you have not ridden in one without it then you will not be able to tell the exact difference in sound level. #JustAGuess
da_jokker
Jeep Wrangler JKUR
Why don't you just opt out? I don't imagine the oem headliner will come out without a fight and leave residue behind.
I don't know if it has been established but I'm thinking OEM from the Factory is Not just a few velcro or sticky strips and probably glued all over.
RG7
B8 A4, 2018 Triumph Street Triple R
Upholstery glue, which I can only imagine is what will be used here, will be a pain to remove. It can be done, but no guarantees on what the top substrate will look like when you’re done, or if the top will have any kind of reaction with the solvent you use to remove the glue. My thoughts are leave it off your order if you’re hesitant. Can always go with hotheads as originally intended
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I thought it was just double sided tape.
RG7
Aftermarket pieces definitely. Didn’t occur to me that the factory would be taped as well. Good catch
Drex
Jake
If Ford is going to install a headliner to almost all Bronco's built, why would an aftermarket company bother producing a kit? There will be no market. Why would you suggest they count on a HH kit being readily available?
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
Probably the same reason many will remove perfectly good OEM wheels and replace them with aftermarket perfectly good wheels...just because.
Mickey21
Mickey
Round Rock, Texas
2021 Ford Bronco Wildtrak (Race Red)
Probably because they are already in that business, can make a superior product, and even factory headliners fail/deteriorate and need replacing. Anything an OEM can do, an aftermarket has the possibility of being better at (mostly because the OEM will remain static typically on quality and options). Not to mention color changes, increases/decreases in density, etc. This is kind of like saying why any of them exist, since the car releases mostly capable of being a car. Some people just like change and not all of them are capable of sourcing the whole thing themselves.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
Because Mark said he’s planning to make one available.
Paging Mark at Hothead (@Hothead Headliners).
Are you still planning to make aftermarket headliner kits for Bronco hard tops in light of this recent announcement? Several members in hotter climates are still interested.
That is still the plan. We don't have any current ETA's yet but we'll keep everyone posted once we do.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
HH has all the infrastructure already to produce. Only thing they need to do is cut their material to a different shape. Minimal investment for an entire new market.
Additionally, some people prefer HH over the Coverking product.
Double additionally, we don’t know what will happen in MY22. Whatever the reason for Ford’s move this year might be resolved and the headliner won’t be offered standard going forward.
RG7
Because the HH kit is intended for heat reduction as well as sound dampening. The Ford kit is not supposed to help with heat. Only appearance and sound reduction.
MacHudson
Northern New Jersey
2012 Edge
I wish someone had done a quantification of how HH product compares to CK. Decibel difference, heat difference. It’s hard to ignore free but lots of self nagging doubt - is it comparable or is HH really that much better?
