Rock Rails/Sliders that will help with do dings ?
We_Love_Tacos
www.bronco6g.com
2021 Ford Bronco First Edition 2Dr Lightning Blue
Rock Slide Engineering steps are awesome.
Ford Bronco Rock Rails/Sliders that will help with do dings ? 8B3B027B-3FCE-4100-93BC-014739407FB6
gtx_bronc
GTX
This issue i have run into is that so many of the modern SUVs have the curved doors that cut out around the rear tire, effectively moving the impact point up two feet making any protection down by the rocker useless. Someone's little crotch goblin slung their door open and left a nice big ass fish eye in my door. I am taking the approach of the more trail stripes I get the less I give a crap about it....same approach as my cracked all to hell and back front windshield. I will replace it when it wont pass inspection
Ford Bronco Rock Rails/Sliders that will help with do dings ? 1660224772686
dcg2
Don
PA
Honda CR-V
Looks like you have to buy their extra mounting hardware tho? I have Bronco OEM tube steps I will be removing. But I hate the extra cost and not mounting to OEM spots.
I had the OEM Badlands sliders. I can't vouch for the OEM tube steps using the same mounting hardware / location. BUT I would be super surprised if they didn't.
You only need the extra mounting hardware if your Bronco didn't come with something. Sliders, Tube steps, Running Boards, etc...
JonDW29
Jon
NoVA
'16 F-150
I have the Zroadz and have definitely heard them collect some flying rocks off the front tires...
Ford Bronco Rock Rails/Sliders that will help with do dings ? IMG_0738
Ford Bronco Rock Rails/Sliders that will help with do dings ? IMG_0739
They still mount to the OEM spots. No drilling required. If you have the Ford rock rails then these bolt right up. The additional mounting kit just replaces the kit Ford uses, as it isn't standard issue.
da_jokker
Jeep Wrangler JKUR
I was 100% set on zroadz and then I ran across bodyguards. The bodyguards mounting brackets are way beefier...spread the load out across the body more, and actually claim to be high lift capable.
Although the zroadz seem like they would block rock kickups better, they just look like a perfect prybar waiting to be bent up.
I'm still a bit torn because I love the look of them.
JonDW29
Jon
NoVA
'16 F-150
Gotta make the right choice for you. The install instructions on the bodyguards looks pretty similar to the Zroadz after a quick glance. The Zroadz definitely don’t ofger Any highlift points though.
Freedom5
Freedom
Snohomish Washington
Classic mini cooper
I just installed the rough country ones last week. They are stout and don’t need any extra drilling for install. Was able to get some use this weekend, held up great on challenging 8-8.5 rated Colorado trails. I mainly went with them because they are functional as a step, seem to tuck close enough to the front fender for blocking most rock chips and they are very reasonably priced.
also, I am not always a fan of needing to use a step, sometime I just like to hop in and out. It is just short enough to allow you to get in or out without the step being in the way.
Do these hide the pinch weld?
FlyingBronco
The Don
Orange County, CA
Freedom5
Freedom
Classic mini cooper
Gpscharron
Claude
Waynesville, NC
2021 FORD Bronco, RV- Ford E450 (Thor Vegas 24.1)
CrytpX
OC
992S, Badsquatch
iag “Great stuff there.
iagperformance.com
Thanks! it's between these and zroadz (slight pricier, but better protection) for me. :unsure:
