Rubberized seat back, wow, that is better
timhood
Tim
Several
Distinction without a difference.
Wouldn't the difference be that the Toyota didn't come with a rubberized seat back either, and as long as Ford offered one as an accessory that would be the same?
Daktari
Oliver
you can see the carpet underneath the plastic thing on the Toyota, I don't think I'd add that. Once caught in the rain you'll have water between that plastic and the seat that won't dry out for a while. I don't mind the carpet, easier to slide things in than if it was vinyl or leather (which also would be easy to damage) and doesn't get scratched up. And if it's like any other car carpet I've encountered it'll dry out quickly should it get soaked. I guess we'll see in a couple months :)
Vooch
SE Penna
2014 Crosstrek xv
I have that on my current Subaru Crosstrek xv. Just great peace of mind when folding down the rears that nothing will be stained/damaged loading crap in.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
My wife’s 2017 Lesbaru Outback came with something like that. It was a factory accessory and worked well.
MyATV
ATL
But will it keep the bodies from being damaged in the back?:unsure:
NCOBX
H2 Hummer, Holden Commodore
I badly miss the completely removable 3rd rows SUVs used to have. Not a fan of the fold flat mess.
Gamecock
Yeah, I don’t see carpet there as a problem, but as working fine for the reasons you state. It’s not an area I’m going to hose out...and carpet holds up way better appearance wise to having things slid across it.
scottyb907
Eagle River, Alaska
74 Ford Bronco, RAM 3500,
The wife Bronco Sport came with an optional snap in cargo liner. It’s pretty sweet, with Bronco had it also, was surprised it didn’t....
wrbix
VA and FL
LR Def90, F250 7.3, Caterham 7, LR Series III, etc
I’m hoping the back seat of 2D is removable with extraction of a few bolts......dog carrying issue solved.
Back seats of my F250, Defender, Element, Grumman, and TTRS are all resting comfortably in my basement.
Firedude
TL
Escape, F150, F250, Miata
I recall reading somewhere on the forum that the seats sit on studs, with nuts holding them down. I had been planning on removing the seats, but if they used studs, unless you grind them off (in which case you can not put the seats back again) you will have studs sticking up out of the floor.
wrbix
VA and FL
....onto which I will apply washers and acorn nuts đź‘Ť
