What did you end up ordering? I'm in the same boat. I have the original ones and not sure which additional ones I need / replace to more beef ones.
On 4 door badlands, you could just add the transmission skid from Asfir. They also sell a bracket for the oem transfer case skid to give it some extra strength. LiteBrite has a video showing their underside with factory skids and they had bent their factory transfer case skid upward, granted it still did it’s job. mine’s a base Sasquatch with mod bumper and bash. I added a factory transfer case skid because it’s cheap and I went with Asfir for fuel tank and transmission. easy installs and so far so good.What did you end up ordering? I'm in the same boat. I have the original ones and not sure which additional ones I need / replace to more beef ones.
I’m not an expert by any means but I’ve done some research. Check out the LiteBrite video where they review trail damage with factory skids. My take away is the factory ones may not hold up for years of bashing, but I wouldn’t worry about using them. I’d buy some rear shock protectors and look into any solutions for the trailing arm brackets for the BL. I’m not sure which ones work with the BL due to the extra piece of steel welded to them.Thanks for the suggestion! people commenting that the factory ones are not strong enough, and I plan on doing rock crawling and want to know that I will not break anything, also ideally I would want to use aluminum to save weight but people also commenting that its not strong enough / slide well on rocks.
All this info just get me more confused..
I would have bought JCR if they didn't have such a back log. I like the recessed bolts and the fact you get a bash plate.Torn between Metalcloak and JCR .....any thoughts on either?
Yeah, the metal cloak setup reused the strap bolts in multiple locations.Do you need to remove the fuel tank straps when you install the gas tank skid?
My tank already a few marks lol.
Don’t risk it. The replacement cost of even the smaller, 2-door fuel tank is almost equivalent to an entire skid plate system from JcrOffroad, and that’s not even factoring in labor for removal and installation.Oh wow. I wonder how durable the plastic is?? I was thinking of getting a gas tank skid but if it can withstand the occasional bump then I might not.
OofDon’t risk it. The replacement cost of even the smaller, 2-door fuel tank is almost equivalent to an entire skid plate system from JcrOffroad, and that’s not even factoring in labor for removal and installation.
BUMPI don’t understand the OEM kit. It includes the front bash plate and engine skid… and is for only the modular bumper… but the modular bumper automatically comes with the front bash plate and engine skid. So do you just have half of the kit as extra parts that aren’t needed? Or am I missing something?
You are understanding it correctly. It doesn’t make much sense. I added Asfir gas tank and transmission skids and bought the oem transfer case skid. Happy with that for nowBUMP
Does anybody have an answer?
It seems crazy to buy this kit and 100% of the time half of the kit is duplicated for the customer it doesn’t make sense.
Thanks for the clarification.You are understanding it correctly. It doesn’t make much sense. I added Asfir gas tank and transmission skids and bought the oem transfer case skid. Happy with that for now
Yeah that could work. I liked the weight savings of the aluminum gas skid and the transfer case skid was only about $50 from ruxerThanks for the clarification.
I thought about that route but the shipping kills it. The kit delivered to the dealer costs the same as just the two pieces from ASFIR with shipping.
I may just get the kit, try to get some money for the front and engine skids on eBay and get the ASFIR tranny skid call it a day
