I want this exact size on a 2-door!Here is our rendering for the 4-door rack! We’ll have more detail as we go along, first step is getting this into a working prototype.
Killer idea and suggestion!@JcrOffroad Please give us a roof rack that allows for removal of the MIC top panels. Put a pivot point on the front, and a non-rattling quick disconnect in the middle joint to allow us to lift the rack out of the way enough to remove the tops.
@JcrOffroad@JcrOffroad Please give us a roof rack that allows for removal of the MIC top panels. Put a pivot point on the front, and a non-rattling quick disconnect in the middle joint to allow us to lift the rack out of the way enough to remove the tops.
No. We don’t even have a physical prototype yet.@JcrOffroad do you have a target date for deliveries you can share?
Take a peek at the 2Door MIC top. Ford’s “wisdom” will be evident when you see it. Unfortunately the 2Door top only has one set of mounting points while the 4Door has two sets.2 door guys, I don’t see why the back half rack wouldn’t work for you.
I’ll buy one as long as on/off isn’t more than an hour. The first solid soft top roof rack on the market will have my money.We have had discussions regarding support mounts for the soft top. Unfortunately keeping the top operational with a rack is going to be a problem.
Take rate = +/- Build ratetake rate says otherwise.
No one cares about the 4 door.
Where’s the rendering for the 2 door?
