So 4A is not what I had thought...
Tswag
Maryland
2022 Bronco
After driving in 4A, I detect a burning smell; also, there's a noticeable drag on the driveline while in 4A, which one can feel while driving (more throttle input to get/keep going) - switching back to 2H regains a detectable "spring in the steps" for the Bronco.
When in 4A, the hubs(or whatever they are calling what locks the wheels to the half-shaves) are locked, so the half-shaves and the front drive shaft spin with the wheel, whether or not the transfer case clutch is engaged. This does create a slight drag o the driveline and is noticeable. It also contributes to the reduced fuel economy in 4A vs 2H.
In slippery mode, the Traction control is "Enhanced" see table below:
Here is a full estimated breakdown of the terrain Management System in the new Bronco aka G.O.A.T. mode.
keep in mind these are only assists. And can be manually adjusted if you so choose.
also doing some digging. Couldn’t really find a big difference between mud and sand. I’m guessing mud is going to be more aggressive.
I'm tempted to write my whole blurb on 4WD here but many have already done it in this and other posts, so I won't.
WheelMe
Patrick
Northern California
2022 Bronco Badlands Sasquatch 2.7L
Great resource with the tables, thank you. It's curious, though, that the table indicates the FR Lock as available for locking in Mud/Ruts mode; in fact, I haven't been able to activate the FR locker in that Mud/Ruts mode, and have had to resort to the Rock Crawl mode for locking FR - is the table incorrect?
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'75 Intl D150/'22 Badlands
I believe you can only lock the front in 4L. In Mud/Ruts it defaults to 4H, but you probably can put it into 4L
WheelMe
Patrick
Northern California
I see. I generally stay in 4H for as long as I can, so 4L usage has been rare for me. Thanks for the tip; I'll give it a try.
Hopeless Diamond
JR
Chumstick, WA
Yeah, 4L unlocks the fun stuff. It also has the benefit of helping with lower auto transmission temps. May not be as much of an issue with these vehicles but in my '96 3g 4runner it lowers them by ~30 degrees. Sucks on the fuel mileage though...
Tswag
Maryland
2022 Bronco
Not fully sure, I haven't had the chance to mess with my lockers, but it is probably when you change it into 4L. The tables list the default settings it goes into those modes, but you can change some options while staying in the mode.
WheelMe
Patrick
Northern California
Yup, I'll be testing it out in 4L - I'm pretty sure that's why I couldn't get the FR locker to activate.
Being deluged with lots of rain these days in Northern CA, I put the Bronco in Sport mode today, triggering 4A - boy was it fun, and no detected slippage on the wet pavement anywhere! it should rain more often.
dgorsett
colorado
F250, Mustang, Explorer
Maybe you’re reading that in an outdated version of the owners manual. Either way, it does not say that anywhere in the newest version available. Here is what it shows:
Edit: Although even this is still slightly inaccurate, because if I remember correctly, 2H is selectable in slippery mode.
You nailed it. Ford changed the language in the Note at the end from "When using slippery mode..." to "Depending on 4wd mode selected" The rockstars discovered and fixed their error.
FleshTuxedo
A
PA
'22 OBX 2dr.
I used Sport tonight and didn’t transfer it out of 4A to 2H, as it’s rainy. I noticed when making turns it was kind of grindy, which I would understand with 4H, but not a slow, not slippery turn in 4A. Something I should get looked at?
edit: didn’t realize this was 8 pages. Going to read through and see if I should be concerned.
HeHateMe
San Antonio, TX
2020 Hyundai Palisade
So... 4A isn't AWD? 🤔
ET13
Honda
4A = Black magic /sssssssssssssssssssssssssss
Tswag
Maryland
2022 Bronco
HeHateMe
San Antonio, TX
No. Awd would require a center differential. The bronco has a transfer case with a clutch.
Potato, potatoe... 🤡
Tswag
Maryland
2022 Bronco
It's an entirely different operating principle. A great video was posted earlier in this thread on the Borg Warner transfer case. It is much different than a differential. This system can lock into true 4wd where most awd systems cannot. Yes when you add computers you could call 4a awd but it's not. You can't put more power to the front than to the back, where with some awd systems you can. Also 4a doesn't have a hand in left/right wheel power, that is still left up to traction control as in any drive mode.
