- Mike
- Jul 16, 2020
- 50
- 917
- 2,256
- Philthy
- Website
- www.instagram.com
- Badlands 4dr 7MT
- Badlands
The 2.3L ecoboost safe limit is around 400ftlb MAX with considerations for longevity..... 350-360 ftlb is where the respected tuners are cutting the torque off, specifically under 3500 RPM because of cylinder pressure. You can make more but it will expose any weakness in the system. Torque is the result of cylinder pressure, but it also lifts heads, bends rods, and exposes weak gaskets. I've been trying to find the limits of the longblock, because that will kinda determine what upgrades are worth the increased performance ceiling they offer, or what upgrades are the best value.
Reference 1:
https://www.focusrs.org/threads/how-much-is-too-much-torque-conflicting-info.49713/
Some hidden gems in that thread. Like:
1. How Ford controls excessive torque with throttle valve and wastegate control.
2. How Ford builds computer control systems in "module format" to work across platfroms, IE trail control.
3. Vaguely describes how the "torque curve" below 3500 is harder on the engine than the curve shifted higher in RPM with less cylinder pressure.
Reference 2:
https://www.thedrive.com/news/30310...le-684-hp-from-2-3-liter-ford-focus-rs-engine
Major points:
1. ALL DI. ALL DIRECT INJECTION. http://www.xtreme-di.com/ Is the supplier here.... This is running E30, but its all DI no IDI or port injection. If you follow me you know. DI systems struggle to FLOW the fuel for the insane HP applications.
2. "Lag" the big turbo for the high HP takes longer to fully spool. Listen close to the soundtrack, the turbo isn't fully "lit" until about 4500 rpm, IMO.
3. E30...... even High test octane isn't enough knock control, meth is needed.....
4. Street or trailability of 1-3...... depending on your application.
Reference 3:
https://www.speedperf6rmanc3.com/pr...-long-block-for-ford-rs-2-3l-rated-700hp.html
1. This is a "700 hp" bottom end build.
2. 2.0L block...(solid deck)
3. Balance shaft delete
4. Keyed Crank, Timing Gear & Crank Pulley
Cross Reference 2.7 TT on big turbos:
https://www.autoevolution.com/news/...-rwhp-shows-off-at-the-drag-strip-137912.html
7MTI550 is the Manual transmission going into the Bronco. Its only rated for 400 lbft.
Love to hear thoughts on the topic from others in the know.
Reference 1:
Reference 2:
Major points:
Reference 3:
