- Feb 21, 2020
- 112
- 7,301
- 25,622
- North Texas
- SUV
- Undecided
Partially correct, 33" and under can be had in the more compliant load range SL, vs 35" load range C, D or E. Stiffer sidewalls make for a less comfortable ride.This is just totally incorrect. 33s aren’t going to provide much different ride than 35s, however the 35s will be a bit softer because of the extra sidewall to absorb the bumps.
There is a LOT of selection in tires in either size, and if you go squatch you can always downsize to 33s if you want.
Maybe there is a crossover point where say a 33" load SL is similar to the taller sidewall 35" load range C?
