Top Down/Open & Windows Up
DallasCajun
Will
Dallas, TX
2023 Ford Bronco Raptor
Question for the group: how stable are the windows when you have the top down/off and windows up? I’ve searched but haven’t found any threads specific to this topic (yet).
I’m still some time away from my Bronco being built and currently driving a Wrangler. I’m not necessarily a fan of the full door frame design when I have the top off. Although, it does give good structure/stability for the windows when I want to keep them up while the top is off. The frameless window design of the Bronco is much preferred but I’m wondering if anyone has experienced issues in this configuration. My assumption is it‘s no big deal as every convertible car out there has the same basic function, but want to see if there’s anything I’m missing.
Of the many features that I prefer with the Bronco is the standard 1/2 doors. While I do enjoy pulling the doors off for a full nekkid ride, it can become a bit of a bear for extended periods. I usually take the top off for weeks/months at a time, but the doors might come off for a day or two here and there. Having a mesh top helps with wind and sun (esp in Dallas) as well. Depending on situation, my wife sometimes prefers to have windows up when the top is off as she actually has enough hair to mess up so I suspect I’ll be driving the Bronco top removed a LOT…and if I’m alone, windows down.
Thanks in advance.
Bonnie6G
Kyle
Denver
Badlands LuxSquatch
The windows seal against the roll cage, so pretty secure when fully up. I have heard of some folks having some window wobble when half down, but I have not experienced that.
ILoveTacos
Eastern Shore Of Maryland
Subaru Outback, Honda Pilot
I've had no issues with the windows up and the top off. If you have the windows partially down that's another story, as they do "wobble" a little over rough surfaces.
Scott R Nelson
Meridian, ID
The only issue that I've had - other than the driver side window motor being dead when delivered - has been in strong cross winds. At freeway speeds, if you have a 25+ mph wind from the side, the down-wind window can pop out of the edges that hold it in place. I had to stop three times the last time that happened to get the window seated properly, then it was good from there on. But rolling it down would have resulted once again in a window that doesn't seal.
The rubber areas that the window seals against don't come off with the roof panels or with the top, so there should be no other issues.
kodiakisland
Arkansas
I experienced about 6 hours of that window being sucked out on the downwind side. It sucks. Loud as crap right by your ear. If you drive along side an 18 wheeler to block the crosswind, you can reset it, but it doesn’t last long.
I’m actually planning to put a suction cup on my window so I can pull it back in next time I drive through South Dakota.
Oneand0
Mario
South Lake Tahoe, Ca
Ford Explorer
No issues either!
Moto26
Tucson AZ
Yep. In fact, with a mesh top like Gear Shade ot J-Top, running with the top down and windows up is actually fairly serene and peaceful driving around town. Freeway speeds aren’t bad - unless, as it’s been pointed out, you have serious cross-winds…
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
bronco0311
South Carolina
No issues at all. I have the top down 75% of the time and I routinely drive over a big bridge to work and it gets really windy. I roll up my windows when I go over the bridge and chill, then roll them down after I come down. Easy as pie. I wouldn't worry about it at all.
LSU Jonno
Huntsville, AL
2022 Bronco
We drive in that config all the time, due to wife hair, just like you. No issues at all, and as someone else mentioned the windows get some support from the roll bar.
Also, Geaux Tigers.
Scott R Nelson
Meridian, ID
I don't consider it to be a problem. And now that I'm aware that freeway speeds in strong cross winds can cause the window to not close properly, I'll just make sure that I don't open the window in those conditions.
Dealer: Kendal Ford in Meridian. They've been excellent for everything.
j_4260
Jonathan
CA
Audi A3, Ducati M620, BMW GSA 1200
I don't have issues with the windows when the top is up or down. I do have some rattle when the window is down part-way, but I recall there is a TSB out to adjust for that and it's not related to the soft-top position.
dukegsd13
Randall
Hartland, MI
2019-MustangPP2 2005-Superduty 2022-Aviator
Thanks in advance.
I have driven the Bronco with all the combos:
All tops off: Windows up. I can hear my passenger next to me. The wind is really, really calm at 70. I was shocked how comfortable everything was. Even at 90 I was surprised how quiet. Hats no issues. Windows down well a little windy LOL. The rear passengers don't like this as much they do sit up higher. All girls need hats I have 4 of them in my Bronco. I did have one wind gust that almost took my hat. No window issues with them all the way up.
Fronts off only: No issues obviously
Fronts and middle top off: This is interesting. I thought this would be my least desired option but I seem to run this the most. It is not bad at all on the highway at 70. I thought that I would get a waffling affect with the back on but no. It's not as smooth as all tops off and windows up but it a close second. The center of the rear top does wobble a tad in the middle. I'm not sure is this combination is good for the rear roof or not. I was a little nervous at first but I don't see any issues.
If my windows are partially down at all any combo they rattle. Need to take to dealer it sounds like they are going to break by rattling so hard. Not sure if the rears rattle.
