Transfer Case Technical Discussion
BigMeatsBronco
Allan
2021 FE 2 door
Oh agree but that is on the other side of the case isn't it? That should be like the simple old gears of the old transfer cases.... I would hope it is happening downstream of the clutch pack but for some reason I doubt it. I bet it is upstream... And that would place considerably more torque on the clutches. Should be able to tell by aligning the input with this power shaft... If the input is aligned with this shaft the gear reduction would have to be down stream... If it is not then the reduction is upstream. (probably)
Very doubtful ford would engineer 3:1 gearing possible with ONLY clutch pack for front axle drive, far more likley the 4x4 LOW Locking mechanism is also used in 4x4 HI
SierraBronco
I believe that portion is the planetary gear set that gives us 3:1, by engaging the two keys on either side, depending on where the motor pushes that sleeve back depends on if it engages BOTH then its 1:1, engage only 1/2 way and it likley reverts to 3:1...the blue shaft shows 3 lines at the wide point which would make sense, first is input side, inner center is for rear drive, and goes through the hollow outer (rearward) shaft for front engagement.
That makes sense. Now I want a video showing that assembly at work 🤣
BigMeatsBronco
Allan
2021 FE 2 door
These bottom teeth attached to shield on the front drive chain gear.
Fit into the shell
Which does not key into the splined drive
The friction coated disks key into the center and steels key into the shell no mechanical connection to the front drive sprocket.
The motor inside the transfer case is operating two things at the same time , the cluch engagement, or the 2wd/4wd hi/ 4x4 low....or at one end of the motors extension it operates the ALL-wheel drive clutch assembly, then you move it all the way to the other side of the range and it likely engages 4x4 hi lock and then beyond that and engages four-wheel low loc... the video does not show the operation in this direction at all he only moves it the One direction. so we can all speculate on the unknown functions 🤣
SierraBronco
Interesting that Ford would highlight the use of having 4H/4L lock for the Raptor trims (and Tremor? These names are so dumb) and not mention it for the rest of the model lineup. With the @Snacktime response on my original post about the issue we were having to check the tcase fluid and not responding to my question on whether there was a true lock or not, it sent me down the rabbit hole where I learned about the use of clutch-only systems that were used on the normal F-150’s, but not Raptors.
Ford Bronco Transfer Case Technical Discussion IMG_6006
article: https://www.sae.org/news/2020/03/ford-raptor-unique-front-driveline
Then going through this thread learned about the overheating issues on the non-locked cases. So it does seem that Ford has no problem with clutch only systems.
https://www.f150forum.com/f118/anyone-thought-adding-4a-xlt-366903/index4/
SierraBronco
Watching this thread eagerly as I was sad lately not having anything to spend thousands of dollars on for my Bronco.
Very familiar with the shitty BW 44-44 transfer cases. I toasted mine drag racing my truck launching in 4wd. The "fix" was just dropping the BW 44-45 that came in lower trims. No part time 4wd but actual lock up when in 4 high.
They did? Do you remember what it was (part/model number)? I don't recall them coming out with a fix.
I think I actually still have my old BW 44-44 laying around somewhere.
order a braptor tcase and pull it apart for us. It only costs as much as getting the brakes to not fall off of your $21k aerospace portals.
5GENIDN
Idaho
Well if I had even taken a glance back at the assembly drawings.... for some reason I was thinking the front and rear output were offset from this shaft... I can be slow... no doubt about that...
You are absolutely right that that shaft HAS to decouple somewhere or you have no change in gearing to the rear.... The rear gear HAS to be happening upstream of the clutch pack. (which does place considerable more torque on the clutch pack). This becomes a problem with larger tires unless of course there is a clutch pack lock out. You defiantly have me questioning there is a possible lock out. I see where you are suggesting it is but still not understanding how it would function... I really want to crack one of these....
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
@BigMeatsBronco that Everest transfer case looks interesting it has 2.72 gears and 4auto. Not sure what transmission they run in that platform are you trying to adapt in a 10r80?
SierraBronco
The Borg Warner 4494 from the Hummer H3 has the very similar gear set to our Broncos and is a four to one ratio in low I wouldn't be surprised if there was a way to adapt this somehow
Oooooooooooooo. That would be pretty awesome
5GENIDN
Idaho
Must be the one I have in my truck..... the H3 Alpha was suppose to be almost identical to what I have... 09 Canyon with the 5.3 4x4.... It does NOT have the all time 4x4... only part time. maybe that was a difference????
BigMeatsBronco
Allan
2021 FE 2 door
maybe, the H3 had a planetary differential with 60/40 split, after and separated from the 4:1 gearset. Id love to try and imstall the 4:1 gears in a Bronco T Case
orion
orion
Jeremy
17' F-250, 17' Explorer
Yes, please do and let us know!
BigMeatsBronco
Allan
2021 FE 2 door
So I asked my buddy, and he's gonna let me borrow the 4:1 T-case from my old H3 and tear it apart and then I can tear down the Broncos case and try to see if there's any compatibility. Keep your fingers crossed!
