- Aug 25, 2019
- 10
- 3,995
- 8,339
- Chicagoland, USA
- '72 Rover, '85 CJ7, '98 TJ, '14 BRZ, '23 Bronco
- Base
Interesting, so if I'm understanding that diagram correctly, rather than have the transmission fluid line run into the bottom of the radiator for cooling (old school method), instead these engines have a separate heat exchanger for that process. And since coolant hoses need to bring coolant to that separate exchanger, there is possibility for a hose coming lose there. Which sounds like happened per the dealer. Kind of bites to have that added complexity and failure points.2.7L EcoBoost (238kW/324PS)
Item Description 1 Transmission fluid heat exchanger 2 Transmission fluid heat exchanger inlet tube 3 Transmission fluid heat exchanger outlet tube 4 Transmission fluid heat exchanger coolant control valve 5 Transmission fluid heat exchanger coolant inlet hose 6 Transmission fluid heat exchanger coolant outlet hose
