- Mark
- Sep 1, 2020
- 12
- 326
- 875
- Lancaster, CA
- 21 Ford Ranger Lariat FX4, 18 Subaru Outback
- Outer Banks
If it's a "known issue" then it's likely there is a Technical Service Bulletin (TSB) that describes the problem, the solution and whether it's under warranty. There are online services you can access to see TSBs but you'll probably have to pay a fee. Access to them was very helpful many years ago when I had some odd issues with my Expedition that the dealer could not duplicate. After 3 years I finally found the TSB that described the issue exactly. Took the TSB to the dealer and they confirmed the problem and ended up replacing the rear axle. I had to do all the research as the SM wouldn't bother to search through Fords TSB database. A little effort on their part would have solved the problem much sooner.I wanted to let everyone know what my dealership experience was like at my local Ford dealership.
At 5500k miles I noticed grease on my driver side LCA during an oil change.
I quickly realized it was CV boot grease. I brought the bronco into the dealership at that time. They confirmed that this was the case and they said that it was a known issue that occasionally the heat press process used to bind the rubber boot to the shaft can fail. The technician said he āhe knew what it was as soon as he saw itā.
They take pics and send them to the person that makes these decisions because their service manager is not in that day. This other person looks at the pics, approves the CV replacement under warranty and away we go. Parts ordered and arrived. Repair day arrives.
Iām told after the fact that the service manager was annoyed because he would not have approved it if he wa at here because of my spacers and 37s.
Note- my CVs are have perfect geometry. This should have been a clearly warrantied repair.
For funsies, I go to pick it up and as Iām pulling away I here the steering linkage clunking. Nope. Back right up to the service bay and shut her down again.
It was the tie rod nut. Clearly it was not tightened or torqued correctly. The tech had match marked it like it was a wrap but the nut was loose by 4 THREADS on the bolt relative to the opposing side (visually easy to compare).
Nope tech insists he did his job and that this is because of a single use nut failure. I am now waiting for 4 more days while they fly in a nut from out of state.
Great.
So I came out on top but just be aware.
