What is this on screen Notice?
Happy
Jerry
Missouri
CJ5, Wagoneer
The last couple of times we turn off the Bronco we get this on screen.
Mid package with push button start stop.
Any ideas what it means? Or Why it shows up?
Ford Bronco What is this on screen Notice? IMG_1273
Ashley
Georgia
21 Ford Bronco, 11 Jeep Grand Cherokee
Check your battery connections. I had a loose one and it did this amongst other errors.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Thanks for pointing me in the right direction.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I just got that today. About 6 hours before that there's a low battery message in Fordpass.
I hadn't driven it for about 48hrs.
RustysBronco
Matt "Rusty" R.
Jupiter, FL
www.instagram.com
It looks like it means its turning the system off to save your battery. 🙂
Turn it on, let the alternator charge the battery up, then turn it off again.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
I have not driven very much lately. So will check all connections and take an Easter drive.
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Drive charging made it go away.
flip
Phil
IN
www.ruxerparts.com
Fords
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Flip should the negative connector on the Battery tender be connected to the nearby grounding screw instead of the battery post?
cowman
cowman
texas
ford
Just as long as it is grounded... that is where I put mine on the grounding screw...
flip
Phil
IN
www.ruxerparts.com
Fords
Anywhere you can get a good bite. Screw, terminal, just as long as it's secure and not painted.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Happy
Happy
Jerry
Missouri
CJ5, Wagoneer
Is yours a daily driver or does it sit for a few days in between?
Our was sitting for a while and I did remember a couple afternoons of work that had doors open until the lights timed out.
