Why isn't Tow Package offered on Base?
ATLUTDFAN
Jeremy
Atlanta, GA & Auburn, AL
2021 Bronco First Edition
It’s not offered on the 4-door FE either. Bugssssssssss
atonge40
Adam
Detroit, MI
2019 Ford Ranger XLT
Can someone explain to me why the tow package isn’t offered on the base model?
"Because go f yourself, that's why"
-Ford Motor Company-
It's irritating because I want a base and to use a rear cargo carrier. I guess I'll have to install one myself.
jdogi
Focus ST
On the BL, I can get Towing Capability to add, but only if i add an accessory that requires the hitch receiver. But then removing said accessory, like the extension ($79) also removes the Towing Capability.
EDIT: I've since found it... duhh
BroncoTPA
Matt
Tampa
I am wondering this also. Has Ford confirmed what the tow package consist of? If it is only the receiver hitch and a wiring harness we should be able to add this rather easily. Any dashboard enhancements should be unlockable using Forscan.
I assume one issue may be gearing however if we jump up to Sasquatch we will have that covered.
toystwo
KY
Avalanche, Tracker, S-10, 911, GTI, Volt, 528i
Ford always showed that tow package is not available on the Base (except in the pricing survey). The tow capacity of the base is the same as any other model so you just have to add a hitch and wiring.
It’s not available on the Base for the same reason things like Mid Pkg aren’t on Base - they want you to buy higher trim levels.
Major_Bullsteak
Alabama
Chevy ZR2 Bison, JK Wrangler
Has been addressed earlier- will be available as a dealer install
Where was it addressed. I would like to read up on it.
