ZROADZ slider / step installed
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
@Bybotie we must have been in the same shipment. I literally installed these on my break from work. Super simple and loving them!
those are great but a Lot of money for what they are.
Frankie945
Frank
Louisville KY
Q50
Do you guys find yourself hitting them or bumping on them getting in and out if your not using as a step.
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
So far, yes. Sticks out enough to bump the calf if you're not using the step. We'll see if muscle memory changes that.
5280Bronco
Denver
I find it hard to avoid hitting my pant leg against the rocker getting out of ours with no step at all. It's gonna be impossible with any step. I'll just have to deal with it.
HorizonHunter
Joseph
Chapel Hill, NC
Stripped some of the body threads for the 10mm bolt. Has anyone tried tapping new threads yet. Super hesitant...
Bybotie
Bybotie
Nigel
Edge ST, 2021 Mustang Mach1 HP, 2021 Bronco
Unless it's the front bolt you have no issues. You can get new brackets if you screw up. The front bolt is a body mount, good luck with that.
HorizonHunter
Joseph
Chapel Hill, NC
@Bybotie Of course it's the front one. 😥
Bracket on one side was just out of alignment, tried to run the bolt hoping it would straighten up. First 1/8 is stripped now and can't get the original or provided bolt to bite.
GeoWar64
Geoff
Sunset TX 76270
I put of a set of ZRoadZ on my Badlands Sasquatch, as well. If you have the factory rock rails, these are super easy to install. No drilling, special tools, or body modifications needed.
Ford Bronco ZROADZ slider / step installed 27428ABC-3C61-45CE-BC86-9F16664AF627
Ford Bronco ZROADZ slider / step installed A478D3C3-2F8C-45AF-9EA5-C2C7CD3B92AF
Ford Bronco ZROADZ slider / step installed 1CFF22FB-523F-4D98-8117-56003D394CB3
Ford Bronco ZROADZ slider / step installed F241C0A9-FB90-4F54-A32F-82D11A687918
5280Bronco
Denver
Looks great! But this confirms my worry about using these in a bronco with standard flares. They are perfect and lined up in the rear with the squash flares, but they are gonna stick out beyond the standard flares which would really drive me crazy for a while. Just something to weigh in the decision.
HorizonHunter
Joseph
Chapel Hill, NC
Nice, if you don’t mind, get some good shots of your Bronco at a reasonable distance so we can see the proportions to the rest of the vehicle. Maybe even a good angle that can show how big the gap between flare and front edge of slider to see how much spray it will block from hitting the doors. I know that’s asking a bit much but it would be super helpful.
https://www.bronco6g.com/forum/threads/zroadz-rail-non-sasquatch-install-troubles-and-review.39787/
idobleedblue
4-door Badlands Sasquatch Bronco
Ordered my set for my 4-door badlands Sasquatch. Looks like about a 4-5 week wait.
BroncoAZ
Mitch
67BroncoG1
Ron
CA
tater_70
Terry
64 Fairlane, 1973 Bronco, 75 F-100
1. Always check your nuts.
2. How do you think they will do with rock protection?
3. Will mud flaps still install fine?
Check your nuts?? (I just had to/two)
clarkscottkent
Kentucky
2022 Ford Maverick
I have seen rock chip question...wondering if anyone has a long term report regarding rocks? I'm curious if flaps will still be needed. I ordered these side steps hoping they'll provide enough rock protection for a cleaner look.
Thanks
