2.7 Oil Change: Took 6 Quarts Not 7
Raptor911
Raptor911
Ashburn, VA
2021 Raptor
Thank you for this. I have been saying that the guys who have been losing their minds over this and using 6 quarts instead of 7 will have a rude awakening a year from now when they start having engine issues.
FSE was here and verified with bronco team engineering, 7.0qt for oil change is correct. My inquiry was the first they had received (through normal Ford channels) and they are investigating. One theory, which appears to be incorrect based on the last post, is they recycled the F150 stick. Beside it being longer, the part numbers are not the same so we can nix that. It's possible there was an engineering change since this 2.7 takes 1qt more than the other vehicles the Nano is used in. Gut tells me engineering spec'd 7qt after the indicator was designed/approved and no one caught it. Anyway, they are "officially" aware of it and looking into it.
Advertisement
one800higgins
VW GTI
So the gist is that 7 is right and ignore the dip stick? Seems like a pretty critical error I would expect Ford to address ASAP, considering the implications of the error and how many people do their own oil changes.
flip
Phil
IN
Fords
So I'm good to pour in another quart? Thanks for finally bringing it to the attention of someone who can get an answer.
Yes. I hate going to the well and using my FSE or tech hotline if we can find an answer with the resources we have available. In this case, all of that was exhausted.
With the size of the forum, I'm surprised more Ford engineering people aren't here lurking. For my inquiry to be the first they've heard is no bueno. Seems like this forum is an absolute wealth of product feedback data and early issue warning system. Meh.
broncorik
Rob
I am at a Ford dealership right now. The parts guy was kind enough to print out the diagrams for both the Bronco and the F150 driver side vlace cover (in which the dipstick resides). Part numbers are the SAME for both (JT4ZA6582A). Dipstick numbers, however, are supposed to be different. Bronco is MB3Z6750B, F150 is L1MZ6750A. I have no idea why they would be different if valve covers are the same, because ultimately either stick should be measuring the distance from the top of the oil to the top of the dipstick retainer tube...and on both engines that should be the same distance, regardless of pan capacity. Is anyone in parts or who has a 2021 Ford F150 able to measure a stick?
flip
Phil
IN
Fords
Top is bronco oil pan, bottom F150. There are differences just looking at the pic but nothing to say differences in depth. F150 refill capacity is 6.0 so one could assume an extra quart would put it over in about the same place as the broncos. I don't have one (F150) in stock to compare and not sure if we even have a truck here that does.
My bet is the stick in the bronco is 1/2" too long and engineering just used the F150 length because of similar parts. They didn't take into account the bronco gets an extra quart.
Lucky Nut
Memphis, TN
97 TJ
How does this explain most people not getting 7qts out during a change? I drained for over an hour just to be sure and got 6.5qts.
cowman
cowman
texas
ford
Guess the engine used some oil between changes...
broncorik
Rob
But the thing is that because Bronco and F150 use the same valve cover, they should use the exact same sticks (unless the check valve system is different) because regardless of pan capacity the oil level when full when measured from the surface of the oil to the top of the dipstick tube should be the same. Simple example...whether or not a small block Chevy (283-400) has a standard 5 quart pan or a racing 7-10 quart pan, the engine uses the same stick. There is no way the 2.7 used in a Bronco should have a higher oil LEVEL than the F150 2.7, even if the Bronco pan has more overall capacity. The engineers should have designed the Bronco pan with more depth to hold the alleged 7 quarts (because they can't go with more width or length), and they should have added a windage tray and/or baffles to keep oil in the sump portion during extreme angles. From the pic you shared, and the ones I obtained, there are zero baffles and there is no windage tray...and no matter why we have the stick/pan combos we have, something is wonky. Running 1 quart low has far less likelihood of doing damage than running 1 quart over. At 6 quarts, the sump is still getting oil because even if Ford did lower the depth of the pan on the Bronco they would have (hopefully) designed a pickup that coincides with that depth.
broncorik
Rob
I got 6.7, and allegedly the filter pleats hold upwards of 12 ounces...that would put my drain at the 34.4 oz (right about 7 quarts).
Rover72
Craig
Delray Beach
06 Land Rover HSE
Vehicle Showcase
Good sleuthing on this!
Can't believe the energy it took to get what should be a simple question to answer by Ford.
So do I understand correctly, the results are the Bronco takes 7 quarts and the stick is not marked properly?
Ford is using the wrong dipstick?
How about this, I would change the oil per the directions, put in 7 quarts then scratch the stick making a mark where the oil level shows up on the stick. Now I have a correct level mark to add oil if oil gets low.
the Duff
East Moline, Illinois
Ford Fusion
I am currently prepping a FE with the 2.7. The oil level is dead nuts at the top of the hashes. This was after the 15 minute drain back. Just seeing if maybe they updated the dipstick. The engineering number on this one is FT4E-6750-BF.
broncorik
Rob
I think Ford, as they have recently been prone to do, come up with cool ideas like a 7 quart capacity oil pan and then drop the ball. With our 2.7s, it would be unusual if the pan held less than even the 2.3s, but they may have had to scrap the deeper pan idea due to space restrictions...or maybe the pan does actually hold 7 and they didn't update the check valve...which seems unlikely because the Bronco block is the same as the F150 2.7 that holds 6, the driver side valve cover in which the dipstick inserts is the same part number as the F150 2.7, yet the F150 2.7 dipstick is a different part number than the Bronco...which makes zero sense. Does anyone in the forum have a 2021 F150 with a 2.7 that can measure the dipstick? Someone posted a dipstick from a 2018, but I suspect they are different than the 2021.
Advertisement
4x4TruckLEDs.com
Advertisement
