JimmyDean
Louisiana
ok, what is that gigantic box in front of the rear view mirror? seems that both the Bronco and JL have it?
Jalisurr
Oklahoma
'09 Corvette Z06, '97 Mitsubishi Pajero Evo
Sensors for lane keeping assist, collision detection, etc is what usually lives up there.
4X4 Lady
Fran
Pennsylvania
2016 4x4 Navigator
Lever on steering column but what’s the blue dot? “Inspected by 4237”? Lol
indio22
Chicagoland, USA
FWIW, the rearview mirror is an old-fashioned "flip" type for headlights (not the electrochromatic or whatever it's called), which could possibly indicate it's not a high trim model (which could theoretically means another screen could be available)?
The JL offers 3 different screen sizes (5, 7 and 8.4 inch). Maybe Bronco will do the same, as it's a great way to make extra cash up-selling. I don't see Ford wanting to miss out on that. But I'm glad to see a smaller screen offering in these "spy" photos. I don't care about screen size and cameras, and did not want one of those tablet-like display things stuck to the dash.
Hard to tell but hopefully the center on down is not overly large and taking up space. That F150 dash in another thread with the huge drive-in theater display and large center console might be good for the F150, but personally I didn't want to see that in the Bronco. Overall I like this horizontal themed dash in the Bronco.
JimmyDean
Louisiana
Would it be possible to remove all that?
indio22
Chicagoland, USA
I wonder how the side window will function. If as previously suggested, there is no integral door frame around the window, then the window will need to seal by having the edges press inward against rubber seals on the body/rollcage structure. In the above photo the camo is getting in the way of seeing exactly how this will be accomplished.
JimmyDean
Louisiana
It’ll likely be an auto up/down half an inch to clear the seal whenever you move the door handle, like most modern convertibles
Paint
Jack
Oklahoma
Tundra
Or like the old Camaros, El Caminos, etc...it just works.
Jalisurr
Oklahoma
Theoretically, you could remove and unplug the module. Might leave an ugly bracket behind, and would probably give you some warnings on the dash though.
indio22
Chicagoland, USA
Interesting, I haven't seen that approach in action. It would be a way to get a better seal, by having the window slip into a groove. Although, what happens with a dead battery, can you get out of the vehicle? Hopefully the battery always has a bit of juice left to activate the window.
JimmyDean
Louisiana
On our tbird you can still open the door, there’s enough flex for the window to pop out the seal without breaking or messing anything up
Jalisurr
Oklahoma
Speaking from experience with my corvette which has the 'indexing' windows, when the battery is completely dead/disconnected it can't roll down, so you have to pull the door a bit harder and the glass slides out of the rubber upper trim. Not a huge deal
indio22
Chicagoland, USA
My old '65 Mustang had a chrome bezel fixed around the window, but otherwise yeah, it made a seal by essentially pressing against the body weather seal, rather than fitting in a groove. I've been in a few other vehicles similar to that, and they seemed to seal ok. Probably not as good as fitting in a groove with more solid frame structure, but still usable.
