- #16
You must be a blind Ford fan boy.Whatever, drink your TRD koolaid.
I have owned over a dozen Fords but I can see the Toyota is better as far as crawl control goes
Agreed the test segment was of the trail control (in particular the spinning wheel braking to force power to the other wheel) to emulate lockers. Apples to apples. I've been wanting to see this in action on the Bronco. The video indicates the Toyota trail control performs better in that regard.What are you talking about? The Toyota made the climb with out lockers. The Bronco could not. Both had their version of trail control turned on. That was apples to apples.
Now he could have found a harder obstacle and did lockers vs lockers if he had of wanted to and that would also have been an equal comparison though I think the Bronco has a front locker and the 4Runner doesn't
If you’re talking about buying a TRD I’d love to see you walk right in and buy one. I have a TRD, it was a six month wait on a list at multiple dealers. Good luck.But you can buy one now and have fun and not the other
what you talking about ,I see one at my local Toyota dealership all timeIf you’re talking about buying a TRD I’d love to see you walk right in and buy one. I have a TRD, it was a six month wait on a list at multiple dealers. Good luck.
Found one for you TRD PRO at Findlay Toyota in Henderson NVIf you’re talking about buying a TRD I’d love to see you walk right in and buy one. I have a TRD, it was a six month wait on a list at multiple dealers. Good luck.
Thanks - I guess these aren’t in demand any moreFound one for you TRD PRO at Findlay Toyota in Henderson NV
I am sure there in demand but when a dealer says call and ask for price I am guessing its more then people want to payThanks - I guess these aren’t in demand any more
Because if you’re testing the top of the line capable 4Runner using all it’s tech, then you should test a Badlands against it using the lockers when needed.Why was it an odd way to test it? The Bronco models that don't have lockers only have that system to get them through the tough spots.. That's what it's designed for.....
That wasn't the top of the line 4runner, and they didn't use all its tech. He specifically states that they didn't use atrac, only engaging the rear locker. Atrac is probably the best brake base traction control on the market today, and is damn near as good as a front locker when used in conjunction with the rear locker. It's not as good as a front locker in slow speed rock crawling, but it's very impressive and a suitable replacement in most conditions that aren't big rocks. The 4runners drivetrain is more capable than the sheetmetal around it will generally allow, at least in stock form.Because if you’re testing the top of the line capable 4Runner using all it’s tech, then you should test a Badlands against it using the lockers when needed.
Otherwise test a regular 4Runner vs a OBX or BB.
Nope .. it was apple to apple. The same technology was used in both vehicles. ONLY that feature was tested but the Ford's didn't workBecause if you’re testing the top of the line capable 4Runner using all it’s tech, then you should test a Badlands against it using the lockers when needed.
They didn't test all of the 4runner's tech just the trail control system on it and on the Bronco. If you watch the video you will see how the Bronco's computer couldn't figure out how to apply the brakes to get the traction needed while the 4runner's computer did what it was supposed too. Crawl control is NOT new technology. Toyota came out with it in 2008. Ford's system needs more work.Because if you’re testing the top of the line capable 4Runner using all it’s tech, then you should test a Badlands against it using the lockers when needed.
