Bronco's trail control isn't as good as Toyota's crawl control
Apples to oranges would be comparing the Bronco trail control to the TDR headlights. It's definitely apples-to-apples, but Bronco has an apple and the 4Runner has an apple that comes with a machine gun.I may have it wrong but I thought trail control was just the off road cruise control / speed management? Not actually shifting power where it is needed? Do I have that wrong?
The crawl control does just that it will drive different wheels based off traction and it needed because no front locker available.
Seems like an apples to oranges comparison.
The Ford system does both- cruise control for the trail as well as brake locking to help with tractionI may have it wrong but I thought trail control was just the off road cruise control / speed management? Not actually shifting power where it is needed? Do I have that wrong?
It uses the ABS system...we have a 2017 TRD Pro and it is odd when it works and you can feel it through the pedals.What was all that racket in the Toyota while in trail control? I'm guessing there's nothing wrong, but wow, it sounds like it's coming apart.
Why was it an odd way to test it? The Bronco models that don't have lockers only have that system to get them through the tough spots.. That's what it's designed for.....I was worried reading the comments until I watched. Odd way to test it out. Not sure I’d have ever attempted what he was trying. Bronco was impressive on the tow test as well.
What are you talking about? The Toyota made the climb with out lockers. The Bronco could not. Both had their version of trail control turned on. That was apples to apples.“Toyoto’s crawl control effectively emulates front and rear lockers” compared to the Bronco’s “Trail control or whatever they call it”. That was dumb. Once they used the lockers the Bronco was fine. Not an apples to apples comparison at all.
Whatever, drink your TRD koolaid.What are you talking about? The Toyota made the climb with out lockers. The Bronco could not. Both had their version of trail control turned on. That was apples to apples.
Now he could have found a harder obstacle and did lockers vs lockers if he had of wanted to and that would also have been an equal comparison though I think the Bronco has a front locker and the 4Runner doesn't
