- First Name
- Nate
- Joined
- Feb 4, 2021
- Threads
- 12
- Messages
- 1,044
- Reaction score
- 2,450
- Location
- Chicago, IL
- Vehicle(s)
- Porsche 911 GTS, BMW M3, VW Golf
- Your Bronco Model
- Badlands
I’m having a great time. This is great.
Whatcha hooking up?I’m having a great time. This is great.
KK 200.4Whatcha hooking up?
Did you get the harness with speaker wire for the 500.1? And you running the power from the battery to the 200.4 ?KK 200.4
KK 500.1
Kicker CS all around
Kicker CompRT 8” in OEM sub box
Yes. I have the harness specifically for the 500.1.Did you get the harness with speaker wire for the 500.1? And you running the power from the battery to the 200.4 ?
So I'm sure you have it all figured out, but just figured I'd throw out my 2cents. You can hook it all up without the adapter, but run your power and ground kit to your battery and through the firewall. Just leave the fuse out and get those cables under your steering wheel. The harness you have now will plug into the kick 200.4. Once your other cable comes in, you just unplug that side and it plugs into that harness which in turn plugs into the 200.4. It will have power and ground wires dangling that you will hook up to the ones already ran.Yes. I have the harness specifically for the 500.1.
I ordered the direct-to-battery harness for the 200.4 but it wasn’t in the box. Currently working it out with PnP. I think it can be added after the fact easily. Hopefully it can.
Great advice.So I'm sure you have it all figured out, but just figured I'd throw out my 2cents. You can hook it all up without the adapter, but run your power and ground kit to your battery and through the firewall. Just leave the fuse out and get those cables under your steering wheel. The harness you have now will plug into the kick 200.4. Once your other cable comes in, you just unplug that side and it plugs into that harness which in turn plugs into the 200.4. It will have power and ground wires dangling that you will hook up to the ones already ran.
TLDR: Once that cable comes in all you need to do is get to the 200.4 and make the connection. Should be super ez
Speaker voltage. It’s the first dip switch on the ampGreat advice.
The 200.4 is under the steering wheel with easy access for tuning and access to wiring. Running power and ground is so easy in this car. You could drive a Volkswagen through the OEM firewall grommet.
Question, what powers off the 200.4 switch if I’m going straight to the battery?
Dont mean to derail, but the backs of your seats looked rubberized. Is this how the Bronco came?KK 200.4
KK 500.1
I and thousands of other people wish they came this way but what Ford taketh away, the aftermarket provides:Dont mean to derail, but the backs of your seats looked rubberized. Is this how the Bronco came?
Mine came with vinyl washout interior.Dont mean to derail, but the backs of your seats looked rubberized. Is this how the Bronco came?
it’s been a week, how did it all good?Yes. I have the harness specifically for the 500.1.
everything works well. The kick panel speakers are a bit muddy but EQ helps. I’m having a terrible time getting the 500.1 to fit behind the side panel. You need to be millimeter perfect in the angle of you want to secure the plate to all four existing bolt holes AND screw the amp at all four corners to the plate. I’m on my third fabricated plate which still needs trimming. More to come once it’s all together.it’s been a week, how did it all good?
