Yes. I had a Four-wheel-drive Toyota Tundra.Have you ever had a four wheel drive vehicle before
I meant an older four wheel drive vehicle, like an old Jeep or something with a transfer case. Meaning depending experience with manual inputs and drivelines working with synced and not synchromesh gearing, chain transfer cases versus gear transfer cases etc. There are a lot odd noises and conditions you can get a four wheel drive vehicle into that could cause jerking. After reading other folks comments it sounds like what you are experiencing is more than just drive train differences and sounds more like computer control of RPM/drivetrain mode.Yes. I had a Four-wheel-drive Toyota Tundra.
He was offroad in a caravan of others driving offroadIām so confused, are you are on an off road trail or driving on the road? If your on the road why are you in 4Lo? Yes the car accelerates differently when in 4Lo because the gearing is very different than 2 or 4Hi. As stated 4Lo is for off-road use only.
I had the auto during the off roadeo and I always had it in M1 or M2 but for one fast section when I put it into 2wd. This was in New Hampshire. I recommend if want to go more than 8 or so mph, take it out of low range. Or get a manual transmission. The higher the transmission gear, the harder a bronco would be to stop if it's in a low range.During the off-rodeo, I was in a Badlands and it did surge in 4L, and like the OP, I do know features and what is normal.... I talked to the instructor and it wasn't normal, and that he had felt it too driving the Bronco I had. No idea why Badlands would be different, it did have Sas, so the 4.46 (??) gearing wasn't in play. It should be the same power train as my Wildtrak.
