Dusty at ICON
Dusty
Riverside, CA
2021 Bronco Base 2-Door
ICON Vehicle Dynamics is excited to announce Stages 3 through 8 of our Complete Suspension Systems for 2021+ Ford Bronco!
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) 20220216_0158-1200w
ICON Vehicle Dynamics is excited to announce Stages 3 through 8 of our Complete Suspension Systems for Bronco! Aimed at improving on- and off-road performance and ride quality, all of these systems feature custom valved ICON 2.5-inch diameter Coilover Shocks for Bronco, with custom front coil springs and triple-rate rear coil springs yielding 3" to 4" of lift over stock, depending on model*. To accommodate the increased travel we are able to squeeze out of the Bronco's suspension, all kits feature replacement front Upper Control Arms utilizing ICON's patented Delta Joint PRO. Higher Stages feature additional shock technology and performance additions as well as links and suspension components which have been engineered to maximize performance.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) IVD-BroncoA-05-2400w
These systems are designed to provide up to 11.5" of front suspenion travel and 14" of rear suspension travel when used with 35X12.50 tires. They may be safely used with 37" and larger tires if using the optional up-travel limiters (sold separately). The factory crash bars (non-Sasquatch equipped Broncos) must be removed to clear 35" and larger tires, but ICON now offers a replacement High Clearance Crash Bar set for those who would like to run larger tires and retain the functionality of the crash bars.
All of these ICON Coilovers and Suspension Systems feature:
  • Improved suspension performance and ride quality over stock
  • 14" Rear Travel; 11.5" Front Travel with 35" tires
  • Vehicle specific tuned front and rear shocks for superior damping and vehicle control
  • Adjustable coilovers from 2.5-4" of lift height (factory set at 2-3")
  • PTFE lined spherical bearings and application specific mounting hardware
  • 6061 Aircraft grade aluminum CNC machined components
  • Corrosion resistant CAD plated coilover shock body with 7/8 shaft
  • High strength alloy CNC machined lower bar pin
  • 100% Bolt-on system - no drilling, cutting, or welding necessary for install
  • Tubular or billet UCA for added strength, durability and an additional degree of caster for better drivability
  • UCAs feature the Delta Joint Pro with 90 degrees of total articulation.
  • Featuring a rear triple rate coil design
  • Rear coilovers are in a shaft up configuration for maximum travel.
Each of our Complete Suspension System stages are built around our precision engineered, race proven ICON shock technology, with increased features and performance with each higher stage. Here is a summary of each Stage, including the additional features each has over the previous stages:
STAGE 3: MAXIMUM TRAVEL
ICON Coilover Suspension Systems for Bronco start at Stage 3 and feature our precision-manufactured, custom valved Internal Reservoir coilover shocks to yield the maximum travel possible along with superior ride quality and suspension performance both on- and off-road. ICON coilover shocks are fully rebuildable. Our coil springs are custom engineered specifically for Bronco. To accommodate the increased travel afforded by the ICON Coilovers, Stage 3 comes with tubular or billet Upper Control Arms which provide caster correction and feature our patented Delta Joint PRO, which allows for up to 90-desgrees freedom of movement. The rear shocks are oriented shaft-up with unique triple-rate coil springs to achieve the most rear suspension travel possible.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) K40003T_web_larg
STAGE 3 Includes:
  • BRONCO FRONT 2.5 VS INTERNAL RESERVOIR COILOVER KIT
  • BRONCO REAR 2.5 VS INTERNAL RESERVOIR COILOVER KIT
  • BRONCO TUBULAR or BILLET UCA KIT WITH DELTA JOINT PRO
STAGE 4: INCREASED COOLING UNDER HARD USE
To provide for sustained shock performance at speed through rough terrain, Stage 4 adds remote reservoirs to the ICON Coilovers. Reservoirs greatly increase shock oil volume and heat dissipation surface area to resist overheating and cavitation under hard use, which can lead to damper fade.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) K40004_web_larg
STAGE 4 Includes:
  • BRONCO FRONT 2.5 VS REMOTE RESERVOIR COILOVER KIT
  • BRONCO REAR 2.5 VS RREMOTE RESERVOIR COILOVER KIT
STAGE 5: UPGRADED REAR SUSPENSION
Stage 5 begins to free up the Bronco's rear suspension articulation while gaining strength and ground clearance with the addition of ICON rear lower suspension links. Available in either billet or tubular versions these links employ dual-durometer greaseless bushings at one end, and a massive FK rod end at the other to provide the best combination of free articulation and ride quality. The billet lower links provide the additional benefits of on-vehicle adjustability and replaceable rock skids.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) K40005T_web_larg
STAGE 5 Includes:
  • BRONCO REAR 2.5 VS REMOTE RESERVOIR COILOVER KIT
  • BRONCO TUBULAR or BILLET REAR LOWER LINK KIT
STAGE 6: DIAL IN YOUR PERFORMANCE
Stage 6 features ICON's exclusive Compression Damping Control Valves= (CDCV) for precisely dialing in your suspension performance. CDCV controls fluid flow under compression, allowing you to achieve the perfect tune whether driving on the street, slow-crawling through the rocks or mobbing across the desert at full throttle.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) K40006_web_larg
STAGE 6 Includes:
  • BRONCO FRONT 2.5 VS REMOTE RESERVOIR WITH CDCV COILOVER KIT
  • BRONCO REAR 2.5 VS REMOTE RESERVOIR WITH CDCV COILOVER KIT
STAGE 7: PRECISION REAR END ALIGNMENT
Stage 7 builds on our CDCV system by adding the complete rear link kit including upper links and ICON's Adjustable Rear Track Bar. Upper and Lower Rear Links are available in either tubular or billet versions. The added upper links have been designed for clearance from the fuel tank during maximum articulation. The Adjustable Track Bar features our dual-durometer greaseless bushing and FK Rod End, as well as on-vehicle adjustability for perfectly aligning the Bronco's rear axle for any lift height.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) K40007T_web_larg
STAGE 7 Includes:
  • BRONCO TUBULAR or BILLET REAR UPPER LINK KIT
  • BRONCO REAR ADJUSTABLE TRACK BAR KIT
STAGE 8: ON-THE-FLY SHOCK TUNING
ICON's Top Of The Range suspension system features lightning fast, precise electronic shock tuning, on-the-fly, at any speed and in any terrain. Focus on driving and let ICON Intelligent Control (IIC) read the terrain and make near-instant adjustments via the Compression Damping Electronic Valve (CDEV) at each individual shock. Control the system wirelessly through the IIC app on your phone. Once configured the system functions without driver input.
Ford Bronco ICON Complete Coilover Suspension Systems (Stages 3 through 8) K40008_web_larg
STAGE 8 Includes:
  • BRONCO FRONT 2.5 VS RR CDEV COILOVER KIT
  • BRONCO REAR 2.5 VS RR CDEV COILOVER KIT
  • BRONCO ICON INTELLIGENT CONTROL MODULE & INSTALL KIT
IMPORTANT TECH NOTES
  • 2-Door models will sit slightly higher than 4-door due to weight difference. For all models, final lift height is subject to variations due to equipment weight and load-out.
  • When running 37" tires, Up-Travel Limiters are required to prevent tire contact with wheel well liners at full compression. These are sold separately (p/n 611075 front; p/n 611074 rear)
  • On Broncos equipped with factory crash bars (non-Sasquatch models), ICON High Clearance Crash Bars are recommended when running up to 35" tires.
  • When running 37" tires, factory crash bars (if present) may need to be removed, and further trimming may be required, to prevent rubbing (not recommended by ICON).
These Complete Suspension Kits will be available for pre-order soon, contact your favorite Authorized ICON Dealer or watch this thread to be the first to know when ordering opens on the ICON website!
EdVA
Ed
Chevy Silverado 2500
Love that more suspension options are coming out…, these look legit!
drew707
Ford Explorer
Awesome to see the live shock option. I'm sure that's quite the price but still very cool and has my interest.
Odd Ball
Cali
HD Vett Mustang Jag 911 (2)450SLs VWcab Blzr Fiat
ICON Vehicle Dynamics is excited to announce Stages 3 through 8 of our Complete Suspension Systems for Bronco! Aimed at improving on- and off-road performance and ride quality, all of these systems feature custom valved ICON 2.5-inch diameter coilover shocks with custom front coil springs and triple-rate rear coil springs yielding 3" to 4" of lift over stock, depending on model*. To accommodate the increased travel we are able to squeeze out of the Bronco's suspension, all kits feature replacement front Upper Control Arms utilizing ICON's patented Delta Joint PRO. Higher Stages feature additional shock technology and performance additions as well as links and suspension components which have been engineered to maximize performance.
STAGE 3 Includes:
STAGE 4 Includes:
STAGE 5 Includes:
STAGE 6: Dial-In Your Performance
STAGE 6 Includes:
STAGE 7: Precision Rear End Alignment
STAGE 7 Includes:
STAGE 8: On-The Fly Shock Tuning
STAGE 8 Includes:
watching...
climb2descend
CA
15'F150
Can't wait. Definitely interested in Stage 3. What's up with that rear bumper also!
kodiakisland
Arkansas
11.5/14 inch travel has my attention.
AK SNO RIDER
Ty
Alaska
I'm extremely interested and watching closely. You guys are the only ones I'm really interested in right now and i sure hope you're doing better than your competitors with their unknown and endless wait times.
Wish i had a favorite "authorized dealer." Would love to see them go live on your site first as I always prefer to order direct when possible. Dealing with all the various 3rd party retailers gets old.
Dusty at ICON
Dusty at ICON
Dusty
Riverside, CA
They should be up on our site soon, but I know of at least one dealer who already has these up on their website and I'm sure many more will beat us to it. We do try to give our dealers a bit of a head start though.
Naxster
Dayton
None
What about CV axle angles in the font when lifting? Any need to lower the front diff like some of the other lift kits? Will you be offering a kit to do just that?
Tricky Dick
Dick
PNW
www.TD-Distributing.com
@Dusty at ICON those 11.5/14 numbers, do you have the figures on how much of a gain that is? Specifically over standard BL which has the most.
kodiakisland
Arkansas
8.7/10.2 was the initial specs I think. Do t know if that’s still accurate.
I’ve also seen 9.4/10.3
SnowBronco
Canada
I was just looking into this and my hr long search found me a 9.4" front and 10.25" wheel travel for the badlands. 🤘
SnowBronco
Canada
Tricky Dick
Dick
PNW
