Draughon
Daylon
Dallas
BMW 4-Series
THAT is damn cool and you're very brave for getting on the highway with that wing hanging on to your roof!
Driving up to 80 mph on the highway no problem!
Jmo0311
Jesse
Kansas City
F-150
I would feel better with it attached to a roof rack. Would be more secure for theft protection and I would constantly worry that I had a kite behind me at some point lol.
rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
Thanks for posting! Curious, what is the monthly fee for this service?
Tex
Cliff
San Angelo
I don't think it would be possible as Starlink uses KA band. If they are using Spot beam technology it might provide some interference protection, but due to the nature of satellite internet I'm pretty sure they use broad or wide beam, which is highly susceptible to interference. Rain and atmospheric moisture is highly degrading to KA band. When I used to work in the Army with had a Radome made of amorphous thermoplastics, specified to be invisible to the signal I don't thing the MIC would due to the core and sound deadening. I'm not 100% what the MIC is made of but knowing how the propagation of signal works, I highly doubt it would work.
I'm pretty sure the hardtop would offer minimal attenuation in KA band, but there would be some involved, so the question becomes whether the losses are worth the application. The top is essentially two thin plastic sheets sandwiching a paper honeycomb, and sound deadening material which is basically plastic thread made into a carpet of sorts. All the materials combined would likely offer similar attenuation to a 1/4" sheet of plastic or polycarbonate. The best option would be to have the antenna flush mounted as close as possible to the top itself in an area of the top as flat as possible. The further away you get from a direct obstruction such as plastic, the more it affects the signal, so if you can minimize the gap you can reduce what attenuation there is. I mean, it's not hard to test if you have the antenna, just set it on top, do an obstruction test and run a speed check , then do the same holding the antenna inside against the top to see what you'd be losing. I'd say it would be worth it just to protect the antenna, but a Bronco hard top would probably fail before the antenna would lol
pillar406
Javier
www.keeseemotorcompany.com
2024 Bronco
Yeah that's kinda what I was getting to because I like to have the best signal as possible. I'd like to keep all my data packets lol
MayhemMike
Mercury
I can’t help but believe the attachment points will eventually cause stress failure on the MIC top. Other then that…nice.
Tex
Cliff
San Angelo
Starlink has so many lost data packets as it is, you probably wouldn't even notice a few here and there from a hard top. It would be like making a carbon fiber license plate mount in an effort to save weight on a semi truck lol
Fortunately it's a pretty robust network so it only manifests as a little bit of lag and randomly pixelated youtube videos, but I get the reason behind wanting to minimize that.
ethanxy
Canada
It looks cool, but in reality, it's not necessary and one big dishy on top will give you more wind noise and etc.
Since Bronco doesn't have a metal roof, so the Starlink antenna signal isn't affected by the Bronco's roof.
Every time I go to the mountains, I plug my G2 Starlink into a portable power source and put it in the trunk, and it always works fine. I'm not sure if the speed is affected, but I'm not too concerned about the maximum internet speed when I'm outdoors.
EL in NH
Ernie
New Hampshire USA
2dr Basesquatch, 2005 HD springer,2010 sporty
you have a trunk?
MyDogGoldie
Charles
SoCal
2.7L BD 4D
internet everywhere
HighVelocity
Big Sky Country
Triumph Scrambler, Ferrari 458
Life is better without internet. But that being said, if it allows u to spend more time outdoors, then that's cool. The technology is great. But I do hate having youtube in the mountains. It kills the vibe.
I mostly agree, however tech like this has made it possible for me to "work from home" on my remote Montana property on occasion, which has vastly improved my life.
KermitBronco
Ian
So. Cal.
2023 Bronco Badlands
$250. Month-by-month for "mobile" (meaning you can have it working while driving). As OP said - driving 80 mph works like a charm.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
They also offer a 12v conversion for the Gen2/Gen3 dish if you want to go that route and get away from having to use an inverter to power it. Wish I had done this for the Broncos. It would solve several installation problems the Gen2/HighPerf dishes present for the limited space in a 2DR.
Does the 12V conversion for the Gen3 work with the cigarette lighter power socket in the Bronco’s cargo bay, or does it require an additional retrofit (e.g., hot & neutral wires with ring terminals back at the 12V battery)? Also, where can I find the 12V conversion kit?
351W-Bronco
Herb
Southern New Mexico
2023 Bronco,1969 Bronco, 2001 Excursion (7.3L)
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
@351W-Bronco hit the nail on the head. I’ve got several of the Starmount Systems mounts and they’re solid.
They also offer a DC conversion for the Gen3 dish that looks pretty slick, but I don’t have one of those. I made my own DC conversion for the Gen2 & High Performance dishes and they work great.
For my install, I ran larger wire from the rear passenger fender well to the factory battery area, but tapped into one of my SwitchPros Sp9100 leads so I can power it while the Bronco ignition is off.
