75w85 rear differential gear oil what are you using
CarbonBronco
Tony
Socal
99 Toyota $runner
For you guys that have changed their rear diff fluid did you stick to motorcraft synthetic 75w85 gear oil? Or use something else? Redline? Lucas? Amsoil?
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I just went with OEM first time around. But, I’m here to see other experiences.
da_jokker
Jeep Wrangler JKUR
Yeah I don't know why Ford Spec'd out such an odd weight oil. Personally I think it is a bummer because I would have liked to had options.
I haven't done it yet, put I'd be tempted to find the rarer 85w and stick to specs. Thicker oils are thicker for a reason and run hotter and with lockers in both my diffs...just don't know if it is worth the gamble.
Aonarch
North GA / MT
Jeep requires the same fluid on their D44s, so it must be a Dana thing.
A lot of Jeep people run 90 with no issues.
I won’t try convincing anyone. I just use 90 because it is more common and I like the squeez packs.
PWillette
Parrie
Maine
FloridaBurgBronco
Don
Middleburg, FL
2022 Bronco Badlands, 2013 F-150 XLT HDPP
I went with Redline 75W85 as well, I like Valvoline too, but I wasn't sure if I needed the Hypoid stuff. Not really sure if that's necessary, but that's the route I went.
toymaster
Leonardo
Wyoming
2023 Badlands
Since the logistical challenges of the p-demic I've fully swapped over to Amsoil. Mail order, decent price, always in stock, even can use paypal to spread out the hurt.
For motor oil I loved Rotella T6, for everything. But with the scarcity and price increase the swap over to Amsoil was easy; just have not swapped back yet. Then I started to use it for all my oil needs. For instance, early this year me and my son bought a bass boat, he lives in another state, so I just do a couple of clicks on the PC, the oil shows up at his door, no hassle, he uses a 'free' to him product and I know I'm doing what I can to have the motor last as long as it can. I change all my fluids early and often.
da_jokker
Jeep Wrangler JKUR
Good to know about the jeep part. I wasn't aware because in mine I went with the higher recommended weight for towing.
builtMIbronco
Zach
Hillsdale Michigan
22 Black Diamond on 37s
I've got 85-140 in both of mine front and rear right now fwiw. Worst case you'll lose a half a mpg from a thicker gear oil, it's not going to hurt anything though.
Jeep has the same specs listed for their gear oil as ford, but if you dig into some Dana documents on the m210/220 axle they call for 75-140. I'm not trying to convince anyone either, I had a case of 85-140 laying around from a project lol
da_jokker
Jeep Wrangler JKUR
When I ran 140 in my jeep, the pumpkin seems to run a bit hotter but can't say I paid alot attention to it before I changed to thicker gear oil.
I will say, damn that ford Spec'd oil is expensive! (Regardless of the brand). Is 85w made of some special magic stuff or what?!
redone17
Cold Spring, NY
I just realized that the front requires 80W-90 (WSP-M2C197-A) and the rear is 75W-85 (WSS-M2C942-A) as already discussed. Why is that?
