Adding a tow package aftermarket
PSUTE
Western Maryland
Sierra
i doubt there will be an available class IV hitch as the vehicle capacity is 3500#, a class III is maxing it out.
It's not always about capacity. Weight distribution is huge when towing. Having said that, properly modified I'd be good with 6000. Cue the "Experts" with no practical experience...
MConn
MConn
Shel
Pittsburgh
Nissan Murano
Iā€™ll get an aftermarket hitch and wiring. I wonā€™t tow anything that will require the factory suspension changes.
I did not know thereā€™s a difference in the suspension.
Can you share anymore info about this? Ive only even bought used trucks that had the hitch already there so Iā€™ve never had the need to think about these things.
PSUTE
Western Maryland
Sierra
Yeah, going over the hitch/recommended tow capacity will require modifications. Tow your jet ski no big deal...
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
considering the available ford hitch is simply four through bolts to the rear crossbar of the ladder type frame, very much similar to the current generation wrangler, custom fabrication would be necessary for the additional weight capacity of a class IV hitch. ford's factory tow package does not add transmission coolers or change spring rates. so i would agree custom fabrication may be necessary...
rdass623
ron
new orleans
mostly factory tow packages are more than a hitch and wiring. generally it is the addition of heavier springs, shocks and at a minimum a transmission oil cooler.
PSUTE
Western Maryland
Sierra
Agree. Just wonder how long it will be before "off the shelf" modifications are out there. You get it, additional transmission coolers are a necessary, and important detail most forget about...
Lakelife36
Ben
Interior of BC
Yup as you say this one doesn't have any of those. I'd be interested in a rail-mounted Class III or IV simply for the added tongue weight capacity and usage of a WDH. The current Class II only allows a measly 350lb tongue weight, when traveling trailers usually have >10% tongue weight. Also since my BB has quite a high GCWR, I would probably push that 3500lb tow cap if I had a WDH on.
Sooner
Ted
Henryetta, Ok
69 F100, 56 CJ5, 11 F250, 17 F150
Iā€™m guessing a good tranny cooler an a set of air bags will do the trick to up the capacity . Iā€™ll probably install the cooler no matter what they make a huge difference in the life of a transmission.
mpeugeot
I don't see why (with the right modifications) it couldn't pull 7500 lbs just like the ranger. It all comes down to the suspension and the hitch.
SuperFord
2013 Ford Fusion
Wiring is easy to do for brake/signal lights. Does not require cutting, splicing, scotch locks, etc. There will be kits that are plug and play.
that would be nice if it were true. & I hope you are correct but unfortunately, I do not think that you are. Iā€™ve got a 4 door first edition on the way next month (of all the nonsense, Iā€™m supposed to get EVERY option, but yet not allowed to choose factory tow package because of the low GVWR).
It does NOT appear that itā€™ll just be a ā€œplug and playā€ affair. The add on trailer tow wiring kit from Ford that is currently listed in the accessories catalog is NOT the same setup youā€™d get factory installed. Itā€™s a generic kit used on many Ford vehicles is not Bronco specific. It DOES require tapping into wiring.
Moabbob
Bob
Corrales NM
2020 Toyota Land Cruiser
Just realized that the hitch for the Bronco is not 2". It won't even hold my bike rack. Looks like aftermarket for me.
TheWoo
Manhattan, KS
2021 Gladiator Mojave
The factory hitch is 2".
Butzy
Butzy
Brookfield, Ohio
f150 & bronco
Ummmm. It is 2" you'll be fine.....
Moabbob
Bob
Corrales NM
Thanks for the clarification, my blurry eyes saw class 2 and thought it wasn't. Now if the rack will clear the spare.
TheWoo
Manhattan, KS
That will be your bigger issue - may have to get an extender.
