Aftermarket Fog Lights - Modular Front Bumper
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
I’m gonna start with some round cheapies off Amazon that go in the removable section. If they don’t work out I’ll switch to the a more trusted brand
Headsong
After seeing how the Broncos sport uses them, where they actually turn when you are turning, I'd love to see something like that. I wonder if any of those from Baja do that?
Philly
Philly
Dallas, TX
2022 JL Rubicon
That would have more to do with wiring and programming the lights than the lights themselves. If the Broncos with factory fog lights do if, you could probably flash the computer with an update and add factory wiring to accomplish the same thing. Would be pretty neat to add!
Buckin Bronco
ChoSunJuan
Canada
2004 Nissan Xterra
Who makes red fog lamps? Look for 2" square ones for the rear bumper.
Philly
Philly
Dallas, TX
2022 JL Rubicon
I’m not sure that anyone makes red, but you can probably get a plastic film and put it over a clear lens.
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
Red fogs for rear use are required in Europe, so there are certainly companies that make them. Hella is one company that does. (https://catalog.hella.com/lighting/lights/rear-fog-lights.html)
Just google rear fog lamp.
Because rear fog lights serve to make your vehicle more readily seen in bad weather (rather than using them to see), its more important for them to be bright than to have a fog beam pattern, per se. So you can use LED brake lights, etc, for the purpose.
Headsong
How about some red drl's? For the rear.
Bronc-O
Phoenix
2021 Lincoln Aviator
Atomicdog
Eddie
Philadelphia
I like this idea because the placement is ideal. I think that rigid has an application for the raptor that fits in a similar place. I also like the application in the overlanding rig.
I would say mounting it on the removable section of the modular bumper is the opposite of ideal.
Philly
Philly
Dallas, TX
2022 JL Rubicon
I agree. They are probably too high up to be street legal in Michigan too, but they will work for those who won’t remove the end caps and will only use them off road.
Did anyone see the off-road fog light kit in the list of accessories that was released the other day? That might not be the correct name, but there was something there. I wonder if it’s a solution for the modular bumper or if it’s just the Rigid light kit Ford has already been advertising.
Atomicdog
Eddie
Philadelphia
I haven’t seen the list but I’ll dive into it this weekend. I will probably hold off on fog lights for a month or two after delivery, I would like to find something to fit in the open section of the modular, below and to the right of where it is mounted in the above pic.
Philly
Philly
Dallas, TX
2022 JL Rubicon
That’s what I’m thinking too. Depending on the time of year, fog lights will go on almost immediately for me. So if Baja Designs has a bracket that will work and still allow removal of the end caps, I will do that. If not, I will figure out a way to mount them myself. I am pretty settled on a set of their lights.
CarbonBronco
Tony
Socal
99 Toyota $runner
i'll be moving my squadron sae fogs over from my current rig.
Bronc-O
Phoenix
They are on the list at a slightly lower price than what they are on B & P.
bem
new york
18 dodge Durango r/t 19 jeep compass
Hi came across these pics for area-51 color, but more importantly it shows factory pod-lites on modulator front bumper
