22OBX
22OBX
Hartford, AL
@kreuselh. Here you go. Take note you will have to remove the storage cubby to make room for the amp panel. I plan to form some metal speaker mesh to cover the opening.
22OBX
22OBX
Hartford, AL
@kreuselh missed the overall length pic. Here it is.
Ford Bronco Another Base Audio System Upgrade Build - Slightly different approach 38F4ADE6-6846-404F-BB54-81A5821C4E9B
kreuselh
Howard
2019 f150 lariat
Thanks. This verifies what I came up with. Getting a Wikdtrak with the B&O system but heard about all the rattling problems with the B&O sub decided to make my own box. Going to put the amp and dsp in the we'll in the middle of the cargo area. Pretty much going try to keep everything concealed as much as possible. Did you have to use any load generating devices?
22OBX
22OBX
Hartford, AL
No load devices were needed. Sounds like a plan.
Slick85
Richard
Austin, TX
Nice Setup! Do you think Morel Hybrids would sound much better than the Alpines or about the same? Thanks
kreuselh
Howard
2019 f150 lariat
Morel's sound a little better. I've used Alpine since the early 80's and already have most of everything for the setup.
Tiresmoke410
Ohio
22 bronco, 16 F250, 66 F250, 68 mustang
What is the need for the sound control LC and the kicker key? Don't they do the same thing?
22OBX
22OBX
Hartford, AL
I am happy with Alpine and have always had smooth sound, and for a fair price.
22OBX
22OBX
Hartford, AL
The LOC provides a lot of flexibility. It allows precise source signal adjustments to minimize distortion, corrects for any bass roll off, allows connections to multiple amps and provides the ability to channel sum signals into a single full range signal if desired. Also if you desire different input source signal voltages to fine tune channel balance.
22OBX
22OBX
Hartford, AL
Some updated final install pictures with all panels back in. I added another section that I can store things under, but also levels the storage space. Also, removed the cubby and added mesh since the cubby doesn’t allow clearance for the amp behind the panel.
Ford Bronco Another Base Audio System Upgrade Build - Slightly different approach 41916E36-0669-4207-8755-ED8C5E42B7EE
Ford Bronco Another Base Audio System Upgrade Build - Slightly different approach 4C33AF87-D8E0-426D-B6C3-B3F1DEB1324B
22OBX
22OBX
Hartford, AL
Has anyone fixed the OEM rattling sub issue without replacing with a new sub?
Obviously as the OP I don't have the B&O with a rattling sub. My setup has 0 rattles. 100% satisfied with this setup as written.
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
I have a rare 2023 that got the sub before the delete..sound is not too shabby with my old ears. Any value in just upgraded replacement speakers? im Not looking for a huge change but maybe clarity. Apple Music sounds pretty good on these now.
ty
22OBX
22OBX
Hartford, AL
ty
You can always improve on factory sound, BUT if your happy stay with what you have and save the cash.
