Antenna mount for CB/GMRS/HAM
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Worked up an rear antenna mount thought I would share.
Bought a Jeep rear tire mount of amazon. Bolt holes were way off as I expected. So did some cutting. After getting it on I realized the tire sat too far back for the antenna to fit. So a 1 inch wheel spacer on the rear tire carrier did the trick. Pics of the interesting parts below. Added measurements of the bracket I modified incase someone wants to make their own
Nicely Done!
Pugsly
Clayton, DE
2014 Ford Fusion
Got mine installed today while doing my tailgate table.
Ford Bronco Antenna mount for CB/GMRS/HAM 0812F5E8-18F9-42D3-AD5D-17F5C071B6D4
cybercoaster
Kevin
Oklahoma
Bronco reserved
You have a wheel spacer on that? I got mine all mounted and hooked up, jiffy have not put the spare back in yet sad I need a wheel spacer I assume.
Pugsly
Clayton, DE
2014 Ford Fusion
No spacer, it’s stock outer banks 18in wheel and tire.
SCTWNB
Newport Beach
Cadillac Escalade
Thank you for the measurements on the bracket. It made it easy to do mine. I used a 1.5" space (I have a Bandlands SAS with 35 in tires. A 1 inch and 1.25 inch would not work for clearance. A 1.50 spacer finally did the trick. I also upgraded the spare tire bumpers and these work perfect. I used the pin from the old bumper, cut off the rubber insert on the new larger bumper and used the old pin.
I also have three extra black 1.50" spacers so if anyone wants to buy one, hit me up. I paid $110 for four of them. LInk to tail gate bumpers and flag holder. https://www.amazon.com/dp/B01BX41WL2?psc=1&ref=ppx_yo2ov_dt_b_product_details
https://www.jerichospecialties.com/store/p288/Fiberglass-UTV-Flag-Poles-Quick-Releases.html
Ford Bronco Antenna mount for CB/GMRS/HAM 20220521_103929
Ford Bronco Antenna mount for CB/GMRS/HAM 20220519_143356
Ford Bronco Antenna mount for CB/GMRS/HAM 20220521_102808
Ford Bronco Antenna mount for CB/GMRS/HAM 20220521_103220
Ford Bronco Antenna mount for CB/GMRS/HAM 20220519_143310
Ford Bronco Antenna mount for CB/GMRS/HAM 20220519_143341
k5wsa
William
Fort Davis, Texas
2022 Ford Bronco, Black Diamond, 4 dr.
This is a great way to mount an Amateur Radio Antenna, as it offers strength that is needed for some of our antennas. I followed this thread and obtained some 3/16" steel plate, to which being a past machinist, fabricated the mount. I also bought the wheel spacers which I think was a beautiful idea to use. As for the two rubber bumpers on the lower side of the tire, I used two 1/2" thick, by 2" hard rubber spacers, and extended the bumpers out to hit the bottom of the tire, to help on those bumpy roads.
Being that you have to buy 4 wheel spacers at a time, I have three that I am willing to part with, say about $30 each and that includes shipping. A bargain!
I mounted my antenna and ran the coax through the same rubber grommet that is on the rear of the Bronco Door, and routed the coax to the radio. But whoever said they used the Auxiliary switch #1, it is only good for 30 amps DC, whereas the Icom 2730A radio needs more than that, and the gauge of wire the Bronco uses is not large enough. The wiring that comes with the radio used 10 gauge wire, and the Bronco is only 18. Furthermore, it is recommended that the radio be wired to the Battery.
With that being said, I think this was a great idea, and I really enjoyed the pics and other comments.
73's and Stay Safe.
Tidy2000
Jon
STL
2017 Ford F150 Raptor SCrew
73's and Stay Safe.
In the past I have wired straight to the battery, but I also saw that the icom wiring harness has a 15A fuse (manual says transmit is 13A) that comes standard, why wouldn’t a circuit rated for 30A be enough?
KANE COUNTY ILLINOIS
SAL
GMC YUKON
To remove the rubber bumpers, did you just pull on the bumpers to take off, which would then expose the plastic fastener? I'm about to clay/polish/ceramic coat the rear door and want to take off the bumpers and then re-mount them once I'm finished with the process! Great photos!
SCTWNB
Newport Beach
Cadillac Escalade
The bumpers have a screw inside. You unscrew them but that did not seem to work so I had to pull them out with needle nose pliers.
ksdon
kansas
Very gently unscrew the plastic screw from the fastener. Don't put any inward pushing pressure on the screw as the threads are very shallow.
RTR Vehicles
Lux Sponsor (Level 2)
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
DenNut
Troy
Denver, CO
Here are some images of our Antenna / Flag mount! Let us know if this helps or if you have any questions.
Ford Bronco Antenna mount for CB/GMRS/HAM 8F5A1808
thanks for those. I would be using the bracket with out the carrier, and really just the bottom bracket on the top hinge. I sand to keep my HAM antenna higher. Any reason I can’t use the bottom plate on the top hindge?
RTR Vehicles
RTR
Concord, NC.
www.rtrvehicles.com
Bronco RTR
We don't recommend installing it that way but the bottom bracket will fit on the top hinge if you choose to do so.
