Anyone go for a cold air intake yet?
ctandc
VA
'22/23 Bronco, 96 EB Bronco
I’m just patiently waiting for AFe to release their non oiled replacement filter. I have used it in multiple vehicles for years. No oil, easy clean, flows better than stock and many aftermarket and did I mention no oil??
Jpursuit
J
Houston
2008 f250 king ranch 4wd, 2021 Bronco
pony2bronco
pony2bronco
Ryan
Maryland
2DR FE
Forgive my ignorance, why go dry filter over a typical K&N?
TX_Bronco77
Travis
Earth
2018 Mustang GT PP
They require more maintenance than a dry filter, and can let the oil or particles through if not cared for properly. They can also gunk up your MAF if you are too heavy handed with the filter oil.
But if they are cared for properly when new they can keep more debris from passing through.
You'll still need to replace an oiled filter eventually and for the cost/time of maintaining it dry is a cheaper easier option.
LethalPerformance
South Florida
www.lethalperformance.com
We installed the Roush intake on our Bronco. They're very easy to install and fit great. We didn't do any back to back testing with it but our truck is tuned and see's more boost than stock so I believe we did benefit from it. We have plenty of the Roush intakes in stock so feel free to give us a shout if there's anything we can help you with.
https://www.lethalperformance.com/r...ir-intake-kit-2021-ford-bronco-2-7l-2-3l.html
We also offer the Whipple high flow replacement filter which is a direct replacement for the factory filter. Here's a link to it.
https://www.lethalperformance.com/w...-filter-oiled-2021-ford-bronco-2-7l-2-3l.html
ctandc
VA
Pretty much what he said. I personally will never run an oiled air filter again. Just my preference. I had a K&N filter years ago when tuning a car - and I chased my tail for WEEKS tuning that thing - turns out it was the oiled filter. This was a total custom EFI setup and the setup simply hated the oiled filter.
I've run aFe dry filters for years. They flow better OEM, they are easy to clean and I've never had to replace one.
While I get it - a "cold air" intake is cool - but for the price you'd gain more power by running 93 octane every fill up.
Felix808
SRV CA
Ford Bronco Anyone go for a cold air intake yet? broncowhipplefilter
The Roush has a nice benefit of the inspection window and a pre-filter sock. I would give it a hard look if I ever changed the intake.
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Lol yeah maybe that dual catch can is available maybe in three years. Their products take forever to release. They should spend less time on blog posts/ pictures and more time on actually releasing products. If I get a CAI I'll go with k&n
MrGreen55
Kyle
Oregon
toyota scion xb
i get your point but... The dual catch can been out for sometime.
https://www.mishimoto.com/baffled-oil-catch-can-system-ford-bronco-27-2021.html
Some people like taking there time to make sure it not going to brake look at funhaver none of there product are out yet.
Bsenecal
Vermont
'19 Ranger crew cab, '17 Fusion sport, '68 Mustang
I always wonder if these CAI increase mpg and HP so easily, why don’t the manufacturers make them standard equipment? Sure would be a selling point to claim additional mpg and HP at a negligible cost. BTW, if you do opt to go with a CAI don‘t go with one that claims it doesn’t require a tune. These units always throw codes after install.
I have had them on 4 different vehicles 2010 F-150 5.4, 2017 Fusion Sport 2.7 twin turbo, 2013 Focus ST 2.0 turbo and 2013 Focus 4 cylinder naturally aspirated.
Every one had both improved performance and mileage.
That’s my firsthand experience.
Still waiting for our Bronco to arrive so no Bronco experience.
Ig_bronco
Matthew
Pittsburgh PA
2014 JKU
Never threw a code on my jk.
wedemmoez
Moez
Dallas
2021 Bronco Badlands, 2007 Porsche Cayman S
My understanding is that CAIs work not so much by taking in colder, denser air but from having improved airflow. Factory designed air filter systems are designed to be quiet, they baffle as much induction noise as possible and in so doing they are quite restrictive. I added a CAI on an Xterra and it did produce a notable increase in power and improved MPG. It also had a notable increase in engine noise and a very notable increase in annoying filter cleanings. I am no engineer but I would speculate that improved air flow would translate to improved MPG with a turbo engine by reducing the exhaust pressure necessary to spin the turbo but would not translate to much in the way of improved HP.
I am an engineer with Toyota, and cold air intakes are mostly marketing garbage. Improved airflow isn't really a thing since its still getting turbulent as it goes in and out of the turbos.
Most naturally aspirated vehicles also won't benefit from smoother airflow since they take a hard right angle going into the cylinders anyways. In older cars it helped because they had mass air flow sensors, so it "tricked" the sensor into thinking there was more air going into the engine, leaning it out a little, and making very slightly more power.
Modern engines (anything after roughly 2005) use an Intake Air Temperature sensor to modify the fuel mixture based on air density and the vacuum pressure inside of the manifold.
TLDR: cold air intakes don't do anything for improved gas mileage or power in modern engines. They do sound different, and whether that is good or bad is up to you.
Inrustwetrust_
Alex
Peoples Republic of Massachusetts
2021 Bronco 2dr
I order KN intake with AFE charge pipe. The intake will be received within one week while the charge pipe in July. I will install it and I will give you my feedback.
Have you got these parts installed yet?
Oden502
Khalid
Qatar
Bronco wildtrak
I received the intake. But for the charge pipes I believe it will be shipped by end of July. Still I dont no if I need to install the intercooler. I am afraid that if I install it without tune it will reduce the power.
